trans problem
Old Apr 30, 2007 | 07:53 PM
90ford4x4's Avatar
90ford4x4
trans problem
i have a 90 ford f150 with a 302 and the tranbs code is a t, it is an over drive, and over drive doesnt work but 1-3 work fine in drive, but when in over drive 1-3 then when od hits its like nuetral can any one help.
Old Apr 30, 2007 | 09:47 PM
90ford4x4's Avatar
90ford4x4
need help please
Old Apr 30, 2007 | 10:16 PM
Trickedout420's Avatar
Trickedout420
i think its an aod
Old May 1, 2007 | 07:24 AM
92F150Flare's Avatar
92F150Flare
Welcome to the forum
This thread is the same problem.......hope it helps
https://www.ford-trucks.com/forums/6...overdrive.html
good Luck
Old May 1, 2007 | 08:43 AM
subford's Avatar
subford
Slipping Fourth Gear (Engine Flare-Up/No Fourth Gear Drive Capability)
Possible Source(s):
Overdrive circuit leakage or blocked passage.
Action(s) to Take:
Check valve body bolt torque.
Possible Source(s):
NOTE:
Burnt overdrive band will help to confirm leakage in the overdrive circuit. Replacing only the overdrive band without finding the cause will result in a repeat service.
Action(s) to Take:
Overdrive servo cover seals leaking. Replace seals.
Overdrive servo piston seal leaking. Replace seal.
Overdrive servo rod excessive clearance in case. Replace inoperative/worn parts.
Overdrive servo cover cracked/porous. Coat cover with fluid. Apply air to overdrive servo, apply passage using Servo Piston Remover T80L-77030-B or equivalent. Observe to see if air bubbles are present on overdrive servo cover. Replace cover if air bubbles are present.
Possible Source(s):
Overdrive servo piston not applying overdrive band/band not applying.
Action(s) to Take:
Overdrive servo case apply passage blocked. «Air pressure test» . Replace case if necessary.
Possible Source(s):
Overdrive band mislocated.
Action(s) to Take:
Overdrive servo piston not seated to the band end seat. Service.
Overdrive band not seated to anchor pin. Service.
Possible Source(s):
Converter damper plate and hub fracturing the weld and/or rivets fatiguing, or the damper springs breaking.
Action(s) to Take:
Perform converter damper/hub assembly weld check procedure. Use Converter Checking Tool T83L-7902-A or equivalent. Replace converter if shaft turns more than two degrees or if there is a grinding noise while applying 50 lb-ft torque.
Possible Source(s):
Direct driveshaft splines distorted.
Action(s) to Take:
Check splines on both ends of the direct driveshaft. Check splines in direct clutch cylinder. Replace direct driveshaft and hardware that splines to it for distortion.
Old May 1, 2007 | 08:45 AM
subford's Avatar
subford
good Luck
In the link you posted, an AOD does not have the plug to un-plug that was referenced.
Old May 1, 2007 | 09:22 AM
92F150Flare
Ok........Guess I'll just stop trying to help......see ya
Old May 1, 2007 | 10:02 AM
subford's Avatar
subford
No, do not do that, you can not help it if someone else posted bad information. Keep reading and posting and you will get more right then wrong I am sure. When I look back on some of my earlier posts I see a lot of things wrong that I wish I could change but I can not.
I am sure he meant well in the link and his information was good for a computer-controlled transmission but not for the AOD.
