detonation/pinging problems 400m
A relatively stock engine won't ping at WOT with those heads; they are just fine. You may get ping when you hit the throttle at highway speeds for a moment, and that could be due to a stretched timing chain. Once you have exhausted all other timing checks and vacuum checks, you may want to check for slop in the chain. Do a compression test, and run some carb cleaner through the engine, and maybe a product that will remove carbon buildup on valves. Carbon can create hot spots that will preignite and cause the knock. You want to do this soon before you blow a hole in a piston, or break something else...
Oh, and a bypassed EGR can be adjusted for be reducing your total timing, but EGR valves are actually a good system in that it allows you to run higher timing for more power. Test to see if it is working. Let it run at idle, and apply vacuum to the EGR vacuum hose and see if the idle gets rough or engine dies. If so, it is working fine. The EGR actuator valve should be tested too. It should provide vacuum for the EGR at speeds above 1500 rpm. If it supplies vacuum at idle, or no vacuum at 1500+ rpm, it is faulty.
I went to a junkyard this morning to scope things out. I found a few f150's and vans with the right motor, and although none had the emissions stuff I was looking for (already nabbed) I got a more clear idea of what I'm dealing with.
that large solonoid type thing on the pass side valve cover is for the smog pump, and much of the associated vacuum lines up there support that.
as you mentioned, since I have a federal vehicle, I'll need a vacuum diagram WITHOUT the smog pump in it. Either that 78 one that you had, or just a guess, wouldn't a 77 one be damned close? I'm dying to see how everything is plummed with the smog pump stuff out of the picture.
about three days ago, I picked up a 78 bronco with a 400m and a c6. I've JUST started to get into it a little, but noticed SEVERE detonation under full throttle. At first, I thought it was just the sound of the flowmasters, but then I saw several others with the same problem on fullsizebronco.com. It sounds like a diesel it's so bad.
I did a good amount of research last night on these motors last night and found that the 351 2v heads used on these motors are quite the garbage, and because of them, the motors are quite prone to detonation, and from what I've heard, is not capable of tuning it out.
so the question goes out to all of you, what's the best way of tuning out the detonation? how far should I retard my timing? any upgrades that can be done on the fairly cheap to help tune it out? will it be necessary to run premium WITH octane booster to get rid of this??
thanks for the help all!
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.c...stributors.htm
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
I hope to use one on all my old Fords soon. What a great service you provide! If one makes changes to his/her engine down the road, can you recurve to suit if it is sent back, or at least recommend the changes to the distributor for the customer to perform?
I've had it only 1 week, but that's ok, that's what I get when my impulse does the shopping. fortunately I'm handy as hell with a wrench, and I'm looking into the possibility of a 460 swap
I've been researching the 460 swaps, and it may not be feasible. From what I'm reading, the late 70's 460's are the best, and I really want to swap in a late 90's 460 (low original mileage) however they say the ports in the heads are different, and the carb stuff may not bolt on....if this is the case, It's looking like I may search out for a reman 400 and drop it in, or rebuild it myself.
I could be pissed or worried, however, maintaining a logical head, no one buys a $1000 29 year old vehicle and expects it to purr like a kitten. It'll be a fantastic truck when I'm done....It'll give me a chance to pull the engine and detail out the new one, detail out the engine bay, and put it all together.
Thank-you!
Yes, we do re-curve our own brand of distributors. If a customer changes his engine combination(new cam, pistons, etc.), he can send it to us to have it recurved OR if he wants to run it in another motor.
In fact, each of our DUI and Duraspark distributors is issued an individual I.D. No., which is engraved on the bottom of the distributor housing. We keep a permanent record of the I.D. no. on file. This way, the customer can call us with his ID no. and discuss whether or not motor changes necessitate advance curve changes.
FTE Sponsor
