adding extra gauges including tach
Old Apr 30, 2007 | 08:18 PM
unixadm's Avatar
unixadm
I bought a cluster off Ebay for around $100 from a 96 F150 and installed it in my 96 F250 7.5L MAF/OBD2 truck. I took both clusters apart and removed my original speedometer and transplanted it into the tachometer cluster. I don't have many local yards out here in CA, so my only real option was buying it online. It was worth the money to me. I know people said if you had a 96, get a 96 cluster. So that's what I did and it worked just fine. I'd try to find a 1997 cluster and if you can't find that, look for one from a 1996.
In regards to where the mileage is stored, it's kept in the speedometer/odometer module which is part of the cluster.
Old Apr 30, 2007 | 08:43 PM
Skandocious's Avatar
Skandocious
Good info about the mileage being stored in the cluster. So Tom you'll be needing to swap the speedometer/odometer module into the new cluster with the tach if you want to keep your mileage true. I think that the walkthrough I linked to earlier accounts for this.
-Chris
Old Apr 30, 2007 | 08:51 PM
unixadm's Avatar
unixadm
-Chris
It does perfectly and the operation of swapping the parts is extremely simple. Including cleaning up the cluster, checking bulbs, swapping parts, and the removal/install, I was done in less than 45 minutes. YMMV.
Old May 1, 2007 | 07:00 AM
92F150Flare's Avatar
92F150Flare
On my 92 cluster swap I had to pull my old speedo and put it in the new cluster for the mileage. I have the digital odometer too. It's in that write-up and very easy to do in my years.......Your 97 and up.....I don't know.
I was going to add a tach in an A pillar mount till I found out how easy it was to swap the cluster.
Good Luck.
81Bronk36
21
Apr 11, 2017 03:17 PM
6.9 diesel nut
Aug 1, 2012 04:16 PM
lgower
19
Oct 30, 2005 11:42 PM
Big Red
Aug 24, 2005 09:51 PM
ROKRAWL
1966 - 1977 Early Broncos
May 12, 2003 09:09 PM
