1978 - 1996 Big Bronco
Tune Up Questions
Old Apr 5, 2001 | 08:49 PM
skipper's Avatar
skipper
Tune Up Questions
Old Jul 1, 2001 | 12:53 PM
jeff80's Avatar
jeff80
Tune Up Questions
My Bronco is badly in need of a tune-up, (running rich, missing, and backfiring) and I thought I'd ask for some advice. I have a 1980 with 351M. It looks like the motor is still making good compression, 126-140 on all cylinders (90k miles). It still has the Duraspark ingition system. I don't want to spend a ton of money as I'm between jobs right now, but I'd like to buy some good parts that are going to work for a while. I thought I should start with a stock set of wires, cap, rotor, plugs and then go from there? I was wondering which plugs I should use as my manual calls for ASF52C, but the parts guys says to use an ASF42C. I believe the 52C is a hotter plug. Would platinum plugs be worth it?
I use my Bronco for light duty hauling, and hunting and fishing. Thanks for the assistance.
Old Jul 2, 2001 | 06:59 PM
AlM's Avatar
AlM
Tune Up Questions
run a test on the ignition..get a haynes or chiltons for the resistance and voltage checks; also check all vacuum lines..do the basics till you have more $ to spend on replacing other parts. good luck!
Old Jul 4, 2001 | 12:39 AM
bigfordman70's Avatar
bigfordman70
Tune Up Questions
Don't forget about all the filters. Air, oil, fuel, pcv valve etc.
BFM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
