Sponsored by: Auxito
How much juice?
Old Apr 29, 2007 | 02:49 PM
zman764's Avatar
zman764
How much juice?
Hey guys in my 97 4x4 4.6 I have a few electrical accessories and I am just woundering how many more I can push. I have the 1 12v dc plug factory, 1 cig lighter factory, I added another cig lighter and put that behind the dash so I could run my satellite radio wires all hidden. The cig ligher I added and hid, I just jumped it off of the fuse from the factory cig lighter. I have a streamlight flash light charger mounted by the cb. I have my cell phone charger. My cb is jumped off of the fuse for something else not sure what it is b/c I did not put it in. For my bday a friend bought me a 12v heated/cooled cooler for my truck and I want to run another cig lighter to the back of the cab and semi permanently mount my cooler.
I also have 2 100W driving lights ran directly off of the battery.
Basically at max capacity here is what I will be running.
Sat radio
Flash light charger
cell phone charger
electric cooler
CB radio
2 100W lights
Is this starting to get kind of high? How much more power can I pull? How do I run a new power line to the fuse box and utilize some of the unused fuse plugs instead of keep jumping off of something else?
Thanks guys
Old Apr 29, 2007 | 08:41 PM
steve(ill)'s Avatar
steve(ill)
a Watt is a volt x amp. 100 watts at 12 volts is about 9 amps load. an 18 guage wire will be good for 10 amps... that being said, your chargers dont pull 1 amp. you could probably run a dozen chargers off the cigarette lighter plug.... the radio im not sure, but probably 8 amps, and the lights pull 9 amps each. if the electric cooler is 100 watts then it pulls 9 amps. you can see you are approaching 35-40 amps. thats not a bad load, you alternator can do it. probalby is you should not run all that off a cigarette lighter. the two lights should have a 12 gauge wire from a 20 amp fuse (to run both). the cooler and radio might run off the cigarette lighter if they are smaller than i guessed. might be good to run alother 20 amp fuse with a 12 guage wire for them as a pair also. you can buy a double or tripple fuse block at aouto zone and just supply it with a new 10 gauge wire from the battery to the new block under the das. run 2-3 different cigarette plugs to the 2-3 different fuses. might be easier than getting into the original fuse box.
Old Apr 29, 2007 | 09:01 PM
zman764's Avatar
zman764
Yeah sounds like a plan. I think the cooler is 60Watts.
The lights are completely separate from everything else. I ran 10 guage wire from the positive battery lead to a 15 amp inline fuse to a switch, grounded the switch then ran that to the lights and grounded each light. I think I am going to try and figure out a way to make a little area for it to fit in between the drivers side of the back seat and in between the non existent door and then run a dedicated cig lighter straight to it off of the battery, or maybe even put 2 or 3 plugs in the back there with it and run them straight off the battery.
Thanks Steve, that is the info I was lookin for!
Old Apr 29, 2007 | 09:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You should be alright. My stereo is pushing 52 Watts to each speaker (4), and I gotta 4 gauge power wire running to my 700W amplifier and to a 12" sub. I am also going to add two, 35 Watt fog lights to the rear of my truck and wire them up to a switch for backup lights. My alternator's got a lifetime warranty, and my battery has a 5 year warranty. I'm not worried! Haha....
Old Apr 30, 2007 | 08:21 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
What is the regular alt rated at?...I had to put one in a couple years ago... it was a 130 amp....
Im running 1400w Lanzar amp with 12 in sub, 4Alpine 6x9's at 50 watts, 2 55 watt fogs 2 60 watt fogs, 80/100 Head lights...
with no problems yet...
Old Apr 30, 2007 | 08:23 AM
BURNSTOUGHFORD
that puts me around 140 amps underfull load with everything going....but i normally dont run the stereo on full...not even half...so im good i think...
brians2000
2004 - 2008 F150
Apr 12, 2013 08:54 PM
mcs58
Feb 4, 2010 03:27 AM
daggerNC
Sep 30, 2008 11:22 AM
rhino_160
Jun 18, 2008 04:14 PM
Shepard
Electrical Systems/Wiring
Apr 10, 2006 07:11 PM
