91 f150
Old Jan 30, 2010 | 12:47 PM
mcs58's Avatar
mcs58
91 f150
hi everyone trying to plug in my cell phone charger and found out that i have no power to the cig lighter all the fuses are good and everything else on that fuse works any ideas? thanks Mike
Old Jan 30, 2010 | 12:51 PM
pete17c's Avatar
pete17c
does the cig lighter work? My cell phone power cord is a very tight fit in the socket .. I need to wiggle it and give a 'real firm' push to get it to work .. otherwise check the wiring to the 'outlet' ..
Old Jan 30, 2010 | 12:54 PM
mcs58's Avatar
mcs58
no i checked the harness as far back as i could and have no power in it
Old Jan 31, 2010 | 10:45 PM
pete17c's Avatar
pete17c
well the cig lighter can put quite a load on the wires .. the may have 'melted' out .. but the fuse should have blown ..
if you don't smoke and don't need the lighter, the easy way out is to just tap into another hot (+12v) and re-wire the lighter socket from there .. but I'd be cautious using the cig lighter with these as you could overload the circuit ..
Old Jan 31, 2010 | 10:54 PM
unrealtrip's Avatar
unrealtrip
If you look at the wire going into the back of the cigarette lighter and try to follow it to the fuse block which if like my F250 is right nearby, you could use a test light or multimeter to check for power on the wire right after the fuse block. If I understand right, the fuse block gets power from a main, then splits it out, so if the fuse is good you should definitely have power coming out. Could be the cigarette adapter itself, or the wire inbetween, but I'd definitely test the line coming out of the block for power.
Old Feb 1, 2010 | 04:43 AM
mcs58's Avatar
mcs58
yeah when it warms up alittle that is what i will try to cold outside right now thanks for all the help ,Mike
Old Feb 3, 2010 | 06:21 PM
danny_g_76's Avatar
danny_g_76
check the wire in the back of the cig lighter if the ash tray was pulled all the way out the wire will pull off or it can rip the wire. you can just pull the try right out and look.
Old Feb 3, 2010 | 06:29 PM
jplinville's Avatar
jplinville
Does it have the stock radio? Chances are, someone tapped into the cig plug power line for the radio and didn't re-connect the lighter.
Old Feb 4, 2010 | 03:27 AM
mcs58's Avatar
mcs58
it has stock radio in it i had it out and followed the wire back to where it went into the big loom and there was no power there
JOEPICKUP
May 14, 2012 09:37 PM
drmitch
Mar 24, 2008 09:01 AM
Turfscape LLC
Oct 13, 2004 06:21 PM
whd507
Apr 22, 2002 08:39 PM
TallPaul
Jul 31, 2001 10:25 AM
