Foil removal
Old Apr 29, 2007 | 11:55 AM
powerstroke1869's Avatar
powerstroke1869
Foil removal
I've been researching on how to remove the foil on my ic pipe but my question is how hard is it to pull it outta the engine becuase it looks all intertwined in the motor and then again how hard is it to put back in thanks in advance
Bobby
Old Apr 29, 2007 | 12:18 PM
Izzy351's Avatar
Izzy351
Here's the thread I started on this:
https://www.ford-trucks.com/forums/5...nsulation.html
The Sol-U-Strip stuff works wonders. That's the way to go.
BTW, the tube pulls right out -- I think all you have to do is remove the intake tube between the filter & turbo. It would be a perfect time to do the CCV mod while you're at it, if you haven't done it already...
Joe
Old Apr 29, 2007 | 02:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
It's not hard to get the pipe out. Remove the air inlet pipe from the turbo to the air filter, and remove the black plastic connector between them with 8mm wrench and disconnect the ccv inlet at the bottom of that piece. Then 7/16" or 11mm deep socket to get the clamps off. The problem might be that if they have never been off, Ford probably oriented the clamp in such a way that its going to be a major pain to get the bottom ones off. You will love the sound but "someone" will be by here soon to tell us we are all wrong.
Old Apr 29, 2007 | 03:05 PM
Izzy351's Avatar
Izzy351
Originally Posted by strokin_it7.3
///SNIP///...but "someone" will be by here soon to tell us we are all wrong.
D@mn, Kris... Between this and your avatar, something's telling me subtlety is not one of your strong points.
Old Apr 29, 2007 | 03:09 PM
PowerstrokeJunkie
my presence is always known
Old Apr 29, 2007 | 03:41 PM
Rich in CO's Avatar
Rich in CO
I got a question what if you remove the foil, and you don't like it what can you re- wrap the pipe with.
Old Apr 29, 2007 | 03:45 PM
450power's Avatar
450power
Why?
What are you going to gain by removing the foil from the Inter cooler tubes, its there to deflect heat.
Old Apr 29, 2007 | 04:10 PM
Izzy351's Avatar
Izzy351
It's actually there to quiet down the turbo whistle. The compressed air on that side is hotter than ambient, so it would more likely retain heat with the wrapping than deflect any. Those of us that remove it just like to hear the extra whistle. Besides, if you wanted to "deflect heat", wouldn't you want to do that on the cold side of the intercooler??
Old Apr 29, 2007 | 04:14 PM
PowerstrokeJunkie
There are two sides to it. One side is that it's there for noise. The other side is that it is there for heat deflection/emissions. I could understand if it was on the "cool" side pipe that has already been intercooled, but the intercooler will wick away any residual heat picked up by the exhaust manifold.
Old Apr 29, 2007 | 08:13 PM
miker67's Avatar
miker67
It takes your engine compartment look nice and clean, instead of looking like it has a sub sandwich wrapped in tin foil stuffed into your turbo. Plus, it makes your turbo sound kewl!!
Old Apr 29, 2007 | 08:47 PM
powerstroke1869
yea tomorrow first thing after work im gunna do that for sure
Old Apr 29, 2007 | 08:55 PM
Izzy351's Avatar
Izzy351
Plan for about an hour and a half. I let the Sol-u-strip work for quite a while reapplying it when it evaporated. Most of the junk comes off with a plastic scraper, but the finishing touch is after scrubbing with the SOS pads...
Joe
Old Apr 30, 2007 | 08:32 AM
F250_'s Avatar
F250_
When you reinstall your pipe, you also need to be careful to get its rotation correct to keep it from rubbing/vibrating against any hard surfaces. Being aluminum, it won't take much vibration/rubbing to work a hole in the pipe.
Old Apr 30, 2007 | 07:48 PM
powerstroke1869
well i took off the foil little bit of a pain but got it all done but does the turbo whistle more at higher rpms or lower thanks for the advice
Bobby
Old May 1, 2007 | 06:26 AM
Izzy351's Avatar
Izzy351
The whistle is louder at the higher RPMs -- but Pete is right. Watch for where the tube rubs. I put some cut-up heater hose over the metal tubing (look at the power steering pump/lines) the tube wants to rub on.
Joe
