6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Bolt Pattern change??
Old Apr 29, 2007 | 10:58 AM
NewDieselGirl's Avatar
NewDieselGirl
I tried to purchase a set of KMC-XD series rims for the 08 which is on it's way.
The tire shop informed me that FORD changed the bolt pattern on the 08's. They suggested holding off until I have a VIN because the rims may not work.
Is this true?
If it is, why change the bolt pattern after the production has already started?
Depending on build dates, the bolt pattern is different. Can anyone confirm this?
I called FORD but they could not answer the question either, said I needed a VIN.
Old Apr 29, 2007 | 10:01 PM
66stang351's Avatar
66stang351
My truck was built week of 19 February and I swapped on a pair of '07 factory option 20's right away. So until then they were the same. I highly doubt they would change in the middle of a run.
Old Apr 29, 2007 | 10:18 PM
EnviroCon's Avatar
EnviroCon
As far as I know the bolt pattern hasn't changed during it's production run.
F-250/350 SRW= 8x170mm
F-350 DRW= 8x200mm
F-450 DRW= 10x225mm
Old Apr 30, 2007 | 07:40 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Is this true?
The only reason they need the VIN for is to work out what sort of model it is (Envirocon covered it)
The pitch circle diametre and the number of hub bolts haven't changed.
Old Apr 30, 2007 | 08:10 PM
NewDieselGirl
Thanks Everyone.
I am calling the tire shop now.
Ford or nothin
1997 - 2003 F150
Aug 16, 2013 09:09 PM
shotgun2
Dec 1, 2011 11:40 AM
gcptc
15
Mar 19, 2011 01:24 PM
davidson915
Sep 23, 2010 06:07 PM
systemofadowntox
Aug 3, 2004 06:37 AM
