1978 - 1996 Big Bronco
Couple of ?
Old Feb 25, 2001 | 02:25 PM
nitro94's Avatar
nitro94
Couple of ?
Old Jul 7, 2001 | 09:46 PM
JoeN's Avatar
JoeN
Couple of ?
I have an 87, 5.0 with about 114,000 on it.
I noticed today that when I'm trying to hold 2000 rpm in park the engine will rev to 2300, then back to 2000, then to 2300, back to 2000. I have a pretty steady foot.Where do I start on this one?
Also my oil pressure was running low side of normal while towing the boat, stopped evry thing was fine, the next day I smelled some oil burning stopped and a section of the dipstick had burnt oil on it. Now to compond it, it seems to be temperature related. I changed oil, new filter. When the temp gets up to the "N" in normal I can pull the dipstick and it's smoking in the same spot(about where it bends around manifold). Also the oil pressure goes way up/down when I get in this range depending on RPM's. When it's below this the oil pressure stays right between te "m" and "a" in normal, where it's been ever since I bought the truck. I also recently started towing a boat.
Is that enough problems, or will this do to start. Thanks for any help guys, I generally lurk and pick up all kinds of good stuff .
Joe
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
