Brake On/Off Switch
Old Apr 28, 2007 | 01:28 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Brake On/Off Switch
If I cut the hot wire going to the BOO switch, will I be able to get the TorqueShift out of PARK position after starting truck?
Old Apr 28, 2007 | 02:10 PM
Franklin2's Avatar
Franklin2
You are trying to eliminate the interlock so you don't have to push the brake pedal to get it out of park? I am not sure looking at the diagrams, but you can try taking the pink/lightgreen wire loose and see what happens.
Old Apr 28, 2007 | 02:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I am wiring in a homemade anti-theft device. Thanks for the reply...I was trying to get away with NOT cutting anything until I know for sure. Ummm, I should to be able to just UNPLUG it from the BOO switch and test it....thanks again!
joe blow
Apr 2, 2017 11:22 PM
Niwrek
Feb 15, 2016 11:26 PM
Whitey Ford
Jun 15, 2015 09:20 AM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
fzeed
13
Feb 18, 2009 04:06 PM
