Squeaky Belt
Old Apr 30, 2007 | 09:40 AM
lrappl's Avatar
lrappl
Ouch!!!!!!
Old May 2, 2007 | 06:17 PM
baitmaster's Avatar
baitmaster
dif deductibles
I bought the 6 yr/90,000m extended warranty with my used '05 a couple mo ago. They said if I use their garage for warranty work it would be a $50 ded, and if it was someone else's (including Ford), it would be $75. The 6 years will be up way before I get that many miles on the truck, so no worries for awhile. Maybe then its time to trade it for another one.
Old May 2, 2007 | 06:22 PM
HomerWinzlow's Avatar
HomerWinzlow
The problem buying the new car ESP is that you have to count the original 3 year warranty against that 6 years. So you really only get 3 years of extended warranty. It is less expensive than a used car ESP plan though.
Old May 3, 2007 | 12:34 AM
F150Texan's Avatar
F150Texan
Originally Posted by Doogie S
To get the old belt off you use a 1/2" breaker bar in the front of the tentioner to release the pressure and then slip it off the alternator. I used a long pipe to provide some leverage and was able to do the job myself in around 15 minutes.
Doug
Changed mine 2 days ago, only took me 20 minutes.
