Performance after chip....impressions?
Old May 1, 2007 | 12:17 PM
yukonsly's Avatar
yukonsly
When you say weak...do you mean....faulty or just not as good as the 17* one...cause...I do not have the $$ just for a HPOP swap...for the fun of it.....Like I say....my tranny is my first concern....aside from putting that sonnax valve in...it's stock...and probably original....it will fail....I know it. I think having the extreme setting reprogramed to something I will use makes more sense now....
What setting would be good? 120HP...High idle...?? do know at this point in time what is available to me...
Yukonsly
Old May 1, 2007 | 04:44 PM
ForemanES's Avatar
ForemanES
Its just not able to keep up with the bigger injectors. Even the superduty guys with the 17* pump need more thats why they usually run a dual pump system, 2 17* pumps hooked together. I think they run about $550. It sounds like your just not interested in the 140 tune so you would be better off getting it detuned and saving up for your tranny. Ask Tony what he thinks a good program would be that wont set the check engine light.
lhud
May 10, 2016 09:49 PM
Royson12
83
Oct 11, 2014 08:53 AM
DIYMechanic
58
Nov 23, 2013 11:28 AM
yukonsly
Mar 10, 2007 12:45 AM
