Sponsored by: Auxito
4x4 frame vs 4x2 frame.. difference?
Old Apr 26, 2007 | 10:53 PM
93PGT's Avatar
93PGT
ok, i know there IS a difference between a 4x4 frame and a 4x2 frame, but im not sure what exactly it is... is it the way its shaped? possibly narrower/wider, higher/lower? or is it just the crossmember?
im thinking all that it could be is the crossmember, but i havent looked under a 4 wheel drive version... does anyone have pictures for comparison? or possible draw it up?
thanks!
Old Apr 27, 2007 | 07:58 AM
96sherm's Avatar
96sherm
i thnk your right on the crossmember idea. given that you can get either engine/powertrain in 2 or 4x i'd vote that their the same except for a spot to put the transfer case, maybe a bit more in the front end...but i'm not a tech.
Old Apr 27, 2007 | 05:35 PM
kharmaguru's Avatar
kharmaguru
Supercab 4x2
SUpercab 4x4
It's hard to see, but there is just an extra cross member at the front of the 4x4 frame. HTH
Old Apr 27, 2007 | 05:55 PM
preppypyro's Avatar
preppypyro
Those frames look very similiar to me. With the exception of the front crossmember. Also something looks different just behind that front crossmember.
Old Apr 27, 2007 | 07:16 PM
96sherm's Avatar
96sherm
almost looks like 2 extra x members, and a support further down...
swampthang
Jun 29, 2014 09:47 AM
Broncodawg
Apr 10, 2014 01:39 PM
Chris Guthro
Dec 11, 2013 07:39 PM
F250Rob
Jan 5, 2011 04:30 PM
