I think im missing parts for brake adjuster on e350.
looking for diagram so i can double check.
I am in process of changing shoes and wheel cylinders and noticed a cable that wraps thru shoe has been cut or is missing, and self adjuster lever is gone, adjustment is only possible manually and i would like to replace missing parts.
All those parts are available at CarQuest or whatever major auto parts store that you have in your area. Inspect the other hardware also, such as springs. Replace them if they show any signs of stretching. These are cheap parts. They will go a long way as to making thing work the way they should.
