Smokin white
Old Apr 25, 2007 | 09:18 PM
parker250's Avatar
parker250
Smokin white
I have white smoke at start up in my 04 F250. I believe that it is a head gasket issue as I am also loosing a considerable amount of coolant, a gallon or so a week. After a while the smoke clears, I suspect that the head gasket is swelling thus limiting the amount of coolant getting in to the cylinders. I am fixin to take it back to the dealer to get fixed. I am interested in either gettin better head bolts or possibly studs. Has any one delt with this thru a dealer in addition to the warranty work?
Old Apr 25, 2007 | 09:19 PM
sglynx1's Avatar
sglynx1
Definately a head gasket... probably be cheaper to get an outside mechanic to do the job for you unless the truck is under warranty, in which case let them mess with it.
Old Apr 25, 2007 | 09:22 PM
parker250's Avatar
parker250
yes it is still under warranty so they will be doing the work
Old Apr 25, 2007 | 11:16 PM
Beerstalker's Avatar
Beerstalker
What engine do you have? If it is the powerstroke a lot of people are upgrading to different head bolts and gaskets. I don't remember what ones but check out the 6.0L forum for more info.
Old Apr 26, 2007 | 03:33 AM
ryaneverk2's Avatar
ryaneverk2
Moved to 6.0L PSD section.
bchitwood73
Aug 23, 2016 06:05 PM
Operator1
Nov 30, 2014 12:02 PM
GonzoCSU
Apr 25, 2011 08:40 AM
redneckkid8331
Dec 23, 2010 08:07 AM
Harley250SD
Jun 25, 2010 12:30 PM
