AIH delete?
Old Apr 23, 2007 | 04:35 PM
fbilly420's Avatar
fbilly420
Question AIH delete?
I want to get rid of the aih on my truck but want to know how it will effect my cold weather start up it gets pretty cold in my neck of the woods in the winter time.
Old Apr 23, 2007 | 05:04 PM
F250_'s Avatar
F250_
From what I understand, unless you like and work in the antarctic, you'll never see all the conditions that are required for the AIH to work.
amiller had the details that are required for it to kick in, and I'll look for the thread to post the details for you.
Old Apr 23, 2007 | 05:06 PM
F250_'s Avatar
F250_
FOUND it!! See post number 4 in the link below.
https://www.ford-trucks.com/forums/5...ght=aih+delete
Old Apr 23, 2007 | 05:18 PM
Pocket's Avatar
Pocket
I deleted the AIH on my truck, and it has seen it's share of sub zero temps without any issues. Also I don't idle my truck for any period of time, so if you do, might consider leaving the AIH in.
Old Apr 23, 2007 | 07:33 PM
jtharvey's Avatar
jtharvey
I had mine out for this particularly cold past winter. I did not notice any negative effects with the way the truck starts, runs or idles. The parameters for it turning on are so strict, it hardly ever comes on. IMO, it's only there for emissions purposes when the truck is idling, the motor's cold and it's cold outside, to prevent some excess unburned fuel in the exhaust.
Old Apr 24, 2007 | 07:15 AM
fbilly420's Avatar
fbilly420
thanks guys for all the input, im going to do it!
Old Apr 24, 2007 | 07:19 AM
fbilly420's Avatar
fbilly420
does anyone have a link to get some pointers on this mod?
Old Apr 24, 2007 | 10:26 AM
F250_'s Avatar
F250_
Look in my signature. Select the web link and scroll down to the Mods section.
Old Apr 24, 2007 | 10:38 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Did this so long ago took a while to find the instructions I used. Here they are. I just went to the parts store and got a plug that fit, then tapped it using the same tap I used to tap my pyro hole.
Decent write-up on what the AIH parameters are too.
Old Apr 24, 2007 | 10:51 AM
fbilly420's Avatar
fbilly420
thanks for the links both of them were in helpful i think i can find a plug at work and do it tonight.
man i got pms bad!
Old Apr 24, 2007 | 10:58 AM
F250_'s Avatar
F250_
I've also read that it is the same as one of the 13mm Dodge oil pan drain plugs, but you would have to confirm that detail by taking your AIH with you to match threads.
Old Apr 24, 2007 | 11:04 AM
fbilly420's Avatar
fbilly420
i am at work now i think ill go pull it out and take a look i have so much crap here i am sure i have some thing to fit.
off the subject do i need to be registered for a certian amount of time before i can do the signature cause i dont see the option to change it like you said.
Old Apr 24, 2007 | 11:31 AM
Tenn01PSD350
i
It should be the very top item when you click on User CP. Is it not there?
Old Apr 24, 2007 | 11:41 AM
fbilly420's Avatar
fbilly420
nope very top is edit e-mail & password
Old Apr 24, 2007 | 11:44 AM
fbilly420's Avatar
fbilly420
should i use teflon tape or a drain plug gasket on the plug. (i found one)
