1978 - 1996 Big Bronco
What kinda freakin' engineering is this?
Old Sep 10, 2001 | 07:52 PM
fast freddie's Avatar
fast freddie
The power lock on the passenger side of my 91 EB stopped working today so when I got home from work I pulled the door panel off with the intention of removing the motor for a bench test. NOT! Looks like the dang bracket that holds the motor in place is riveted in. This can't be right ....can it?
ps. I was able to get a can of WD-40 in there and spray into the motor (the little rubber boot on top is shot) and got it working again but I think it is just a matter of time.
Old Sep 10, 2001 | 08:16 PM
ecarter50's Avatar
ecarter50
the motor can be removed without the bracket it snaps in with rubber bushings
Old Sep 11, 2001 | 04:57 AM
fast freddie
I tried prying the bracket apart but it felt like it might break. I'll give it a another try. Thanks for the reply.....
Old Sep 11, 2001 | 07:01 AM
JBronco's Avatar
JBronco
I have the samwe problem. Even if you get it out, the replacement at the dealer is 100 bucks! I'm going to try a junkyard, others have suggested aftermarket actuators.
Old Sep 11, 2001 | 04:14 PM
JBronco's Avatar
JBronco
Went to my local boneyard, no actuators. I'll let you know if I find a source. If I have to pay 100 bucks + it will be a while before I do this, it's not essential especially on the driver's side. I'd rather get my windows tinted.
Old Sep 11, 2001 | 04:22 PM
JBronco's Avatar
JBronco
I haven't found an actuator yet, but here is a link that should help make the job easier (cut and paste)
http://members.tripod.com/sparkplugs/doorl.htm
Old Sep 13, 2001 | 05:57 PM
JBronco's Avatar
JBronco
Just found out that most any Ford actuator will work, just have to change the rod. So that should make it easier to find one.
Old Sep 13, 2001 | 05:59 PM
JBronco's Avatar
JBronco
