Concrete Cleaner?
Old Apr 23, 2007 | 06:42 AM
marragtop's Avatar
marragtop
Concrete Cleaner?
Can anyone recommend a good cleaner to remove oil stains from concrete? Thanks.
Old Apr 23, 2007 | 08:44 AM
CobraXP's Avatar
CobraXP
I don't know the brand name of the stuff I bought at Lowe's, but it was a reddish/pinkish color liquid in a white gallon jug. The label has some brown on it. I know this stuff will eat through any stain on the driveway and remove it.
(I'm going to move this to the General Discussion forum. Might get some better ideas in there... )
Old Apr 23, 2007 | 11:08 AM
jim henderson's Avatar
jim henderson
Yeah the Hardware stores have some decent cleaners. There is an oil cleaner and a rust cleaner, they handle different stains of course. I thnk Jasco is one of the brands I have used with good results. Some oil stains leave a shadow so you might not get it all.
If you want an excusee to buy a new tool, you might look into a pressure washer, get a big one say 6hp or bigger, otherwise you spend all day cleaning.
If you are looking for a pressure washer checkout the "factory seconds" and "returns" section of the store, sometimes you can find really good deals. I got my 8hp Generac for something like $100. It was brand new, the previous year model and missing the hose and wand. I called Generac to order the parts and they sent me the whole kit for free, bless em.
Good Luck,
Jim Henderson
Old Apr 23, 2007 | 12:15 PM
marragtop's Avatar
marragtop
Thanks for the replies. I do have a 6.5hp (2300 psi) power washer. I didn't have much success with that removing the stains with just water. Once I identify a decent cleaner, I will probably let it soak for a half hour or so and then hit it with the power washer.
Old Apr 23, 2007 | 01:22 PM
ranger1999 Bob's Avatar
ranger1999 Bob
ZEP makes good stuff too you can get good soaps at home depot or lowes then like ya said hit it with the power washer
Old Apr 23, 2007 | 02:57 PM
FTE Ken's Avatar
FTE Ken
Muriatic acid.
Old Apr 23, 2007 | 02:59 PM
wrobo23's Avatar
wrobo23
i've used watered down bleach, squeegeed off, and shot it with a pressure washer... always seemed to work for me.
Old Apr 23, 2007 | 07:19 PM
Mil1ion's Avatar
Mil1ion
I use muratic acid for etching a concrete when I am going to paint it.
If you just want to get the grease out.
Use some Varsol or lacquer thinner first.
Then use T.S.P. with laundry detergent
Then rinse with a bucket of hot water
Make sure the broom/brush is stiff.
Old Apr 23, 2007 | 08:27 PM
tdister's Avatar
tdister
Tide with bleach worked in with a push broom and then hit with a pressure washer worked pretty good for me.
61 uni
17
Jan 5, 2010 09:48 PM
wlihntr
Aug 30, 2005 10:36 PM
Marc150
Jan 7, 2005 05:00 PM
FLgargoyle
Aug 15, 2004 12:55 PM
Gouge
19
Nov 22, 2002 02:55 PM
