Kris, just a thought. What wastegate does the bigger housing run? Could it be opening to early? Or not working right with the bigger turbo? More Fuel needs more Air right maybe even though the turbo is bigger its wategate isnt allowing as much air?
Mike, I know he's still got the stock IC. I got a look at it last week to be sure. But, it's the one with plastic end tanks and I'm wondering if there's not a leak at the seam there. My buddy blew the end tank on his stock IC of similar design...granted it's a Dodge...but still possible.
I was just wondering, would he still have lower or more effiecient boost #s moving more air with his turbo setup. I would think that has something to do with it. His turbo wouldn't heat the charged air as much as my stocker.
He will still have lower boost numbers than a similar equipped truck with a stock turbo, if that's what you're asking. More air moved at lower boost with his turbo setup, when compared to a stock turbo.
That is exactly where I was going. The lower # does not necessarily equate to a boost leak or problem, just air being moved more efficiently. Just like your air intake temp tests revealed.
I think though, what Kris was saying by a lower boost # was compared to what he's run previously with the same turbo setup rather than compared to a stock turbo. I think he should see a peak of 25-27 psi when he's accelerating from at dead stop, at WOT, when the truck shifts into OD.
