Sunroof
Old Apr 22, 2007 | 03:35 PM
bktabolts's Avatar
bktabolts
Thumbs up Sunroof
New to the group/forum. I have a 97 expy EB and I have been noticing that there is a little water seeping onto my headliner on the drivers front corner. Is there a gasket/seal that will cure that problem. I've been told that when your sunroof starts to leak it's hard to solve the problem. Any help would help.
Old Apr 23, 2007 | 08:15 AM
robbizkit's Avatar
robbizkit
sunroof leaks
last fall, after many attempts of my own, i took my 2000 expi to my local dealer because I had the same problem, only it started soaking the pass. seat. The end result was 145.00 to flush the driver side drain tube with some cleaner, and un pinch the drain line on the pass side. It must have been installed this way origionally because it had never been apart. The pinched line caused flow to be restricted. Apparently these drains run down the A pillars then behind the kick panels and out the floor. Hope this helps.
tmt40
Jan 24, 2006 06:22 AM
salty
Jul 31, 2005 06:49 AM
rdrakea
May 4, 2005 10:33 PM
ExpoBoi99
Mar 13, 2004 04:34 PM
Yankee In TX
Aug 20, 2003 08:18 AM
