Scanning ABS Codes
Scanning ABS Codes
My ABS light is coming on and I see there are codes that can be scanned to help analyze the problem.
I have a scanner (Autotap) but it only does drivetrain codes for some reason. Is there something different about ABS codes? I assume they they come out through the same connector as the other codes - correct?
I hope this isn't one of those things where you need a $1000 scanner only available to dealers who know the secret mechanics' handshake
I had an ABS light come on my 99 EB and it turned out to be a rear speed sensor(on top of the rear diff). It costs around $23, held on by one screw and one pulg. This seems to be a pretty common problem on this model. Do a search, there is thread that has pictures on the replacement.
davisenvy - I found that the rear speed sensors are a common failure item. I found in the repair manual a test procedure for the speed sensors that involves measuring resistance between the sensor leads and ground. I'm going to pull my meter out and test the sensors - maybe one of them will turn out to be the culprit. I may replace the rear one anyway given it's low cost.
If that doesn't work, I'll have the bread down and pay a shop to scan it for me.
ryanf77
Sep 2, 2024 08:17 PM
