Sponsored by: Auxito
Won't Shut off
Old Oct 21, 2002 | 12:13 AM
Blue98's Avatar
Blue98
Won't Shut off
Got home tonight, and turned off key, but truck kept running! I had to pull the fuse for the coil to get engine to shut off, but the indicator lights in dash stayed on. I ended up disconnecting battery. I'm guessing bad ignition switch, but not sure because while driving home, I turned on left turn signal, and got 4 way flashers. Has anyone experienced this or can offer advice. Truck is a 98 with 5.4 and 24000 miles. Any help will be appreciated
Old Oct 21, 2002 | 12:45 AM
Racerguy's Avatar
Racerguy
Won't Shut off
I would take a look at the fuse box and see if there is water in it from a leaky windshield. Usually when they get water in them things like the heater wont shut off but I guess anything is possible
I've replaced quite a few fuse boxes for this problem.
Old Oct 22, 2002 | 01:13 AM
chevrolet's Avatar
chevrolet
Won't Shut off
Old Oct 22, 2002 | 02:55 AM
chevrolet's Avatar
chevrolet
Won't Shut off
It's hard for me to imagine water in the fuse panel being able to conduct enough electricity to make the coil fire. But like you said, anythings Possible. But I would probably look somewhere else. If you have a tilt colum, it's possible that it could be pinching the wires, causing a short, which could explain the not shutting off, and the signal problem. If you do have a tilt colum, maybe try starting the truck, turn the key off, and then see if the truck will shut off by moving the colum around.
Old Oct 22, 2002 | 09:24 AM
Racerguy's Avatar
Racerguy
Won't Shut off
Well I know that water in the fuse box can conduct enough electricity to keep the heater fan running on high....seen it quite a few times.
Old Oct 27, 2002 | 06:48 PM
Blue98's Avatar
Blue98
Won't Shut off
It turned out to be a problem with aftermarket remote start module. took it out, and truck shuts off now. Thanks for your resonses.:P
Perry Calvert
Feb 3, 2016 08:49 PM
fordtruckguy98
Oct 25, 2015 10:10 PM
akahabka
2004 - 2008 F150
Oct 10, 2015 01:46 PM
andrew14
Dec 4, 2014 09:58 PM
larrylass
Aug 30, 2012 12:26 PM
