91 F-150 help???
Old Apr 21, 2007 | 09:27 PM
road_dawg_30's Avatar
road_dawg_30
Cool 91 F-150 help???
Just got a 5.0 EFI. puter showed TPS and O2 sensors bad...changed both..truck idles well, put it in gear idle gets rough, accelerate slowly it smooths out, give it some fuel it gets rough again, tries to shake you apart...ran the truck for awhile, left it idle in drive, still idles good and if you accelerate while in park, no problem that you can feel, killed it, won't start until it gets cool. Will try about anything, truck is showing 94,000. has new IAC and good pressure at rail????
Old Apr 21, 2007 | 09:41 PM
adrianspeeder's Avatar
adrianspeeder
What is the pressure?
Adrianspeeder
Old Apr 21, 2007 | 09:45 PM
road_dawg_30
right after the truck died it was 45 psi
Old Apr 21, 2007 | 10:16 PM
andym's Avatar
andym
WAY too high. It should be 35 psi. Pull the vacuum line off the fuel pressure regulator. I bet you'll find gas in there, which means it needs to be replaced.
Old Apr 21, 2007 | 10:39 PM
albung's Avatar
albung
check coil and computer temp sensor also wiring around coil
Old Apr 22, 2007 | 07:49 AM
EPNCSU2006's Avatar
EPNCSU2006
45 is about right for no vacuum condition
79FordBlake
Sep 26, 2013 08:07 PM
fourseasonsmi
Dec 19, 2012 12:10 AM
leonard600
Sep 2, 2010 02:55 PM
quikf250
Feb 7, 2007 01:12 AM
Pam's Red
1978 - 1996 Big Bronco
20
Aug 21, 2004 06:06 AM
