Major problem need help.
Old Apr 21, 2007 | 09:12 PM
78ford_shortbox's Avatar
78ford_shortbox
i just put a 400 into my 78, i turned the key and nothing happend, all the lights came on like normal but the starter didn't click or anything. any help is appreciated
Old Apr 21, 2007 | 09:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
That is in no way a major problem. Starter solenoid, battery connections, neutral safety switch, or key switch. Get your test light out!
More info just a few posts below this one.
https://www.ford-trucks.com/forums/6...er-by-key.html
Old Apr 21, 2007 | 09:25 PM
Mrcorey5's Avatar
Mrcorey5
Did you ground the new engine directly to the battery?
Old Apr 21, 2007 | 09:34 PM
Alvin in AZ's Avatar
Alvin in AZ
Like Torque, I see it as an easy one. :)
Time to call in one of your favors since you don't have a meter or know how to use one. :/ Get your favor returned from your friend that has a meter and knows how to use it. :)
No favors?
No friends with a meter?
Well ok, yeah, it's a major problem. :/
Start swappin out new parts until the trouble clears up. ;)
Bring money. ;)
Alvin in AZ
Old Apr 21, 2007 | 11:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
For this one no meter required, all he needs is a simple test light.
Part Number: 648344 $3.49 at Advance Auto Parts...
http://www.partsamerica.com/ProductD...egoryCode=3391
Old Apr 22, 2007 | 11:15 AM
Mil1ion's Avatar
Mil1ion
For more info see the other active threads on the " no start " topic.
There are a couple loaded with info.
Old Apr 22, 2007 | 09:14 PM
78ford_shortbox
well thanks for the help and it turns out i hooked the starter cable between the piece of brass and the metal on the starter so i am an idiot but it's all working good now.
Old Apr 22, 2007 | 09:27 PM
rawelschjr's Avatar
rawelschjr
Try this
Sounds like a loose ground off the solenoid. Check all the wires from the Battery to the starter, and back to the block.
