Man...I just got back from Iraq so I'm a little bit behind on the times, so what's the deal with ignition recall?
And CPS? I'm still running the original, and what's the matter with it?
Welcome back, and thank you for your efforts.
Nothing is wrong with your CPS, unless something is wrong with your CPS. They have a habit of failing, and the replacement is typically around $100 or more depending if you buy it from International, Ford, or somewhere else. Apparently the International and Ford versions are better than the aftermarket versions. Most here carry a spare in the glove box; takes a few minutes to swap it out.
Can't help you with the ignition as I don't know anything about the issue.
Solid Ground - Ford had an Ignition Switch several years ago and did the same deal with the price of the part just prior to the recall. NOT THE SWITCH FOR OUR TRUCKS.
Heard it from my neighbor he works in the Fleet maintenance department, I cant see ford doing a recall but they have done price drops on troublesome parts before.
