Sponsored by: Auxito
AC Question
Old Apr 21, 2007 | 06:47 PM
ljones0525's Avatar
ljones0525
Question AC Question
My AC blows cold at low fan speed. When the fan speed is increased the door/doors in the ducts flop and it goes to 100% heat. Any sugestion as to what or where to start? I assume I have vacume but I am guesing that I have a bad actuator. I just have no clue where thay are or if this is it.
Old Apr 21, 2007 | 08:00 PM
LxMan1's Avatar
LxMan1
Welcome to the forum;
Sounds like a broken blend door. I've heard they aren't real easy to get to. It's in the duct work.
Click on search in this forum and type in blend door. There are several threads on this.
Old Apr 21, 2007 | 08:44 PM
torkum's Avatar
torkum
Pull the black vented cover off thats under the dash and over the tranny hump to watch the functions of the actuator when you change the fan speed.
Old Apr 21, 2007 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
the vacuum controls where the air comes out, either defrost, dash or floor. the "temperature" is controlled by the blend door that is electric operated. it mixes the cold air from the AC with the warm air from outside and "mixes" to get the temp you want. it does not change or should not change position when you move the fan speed. if the door is broken, then the wind speed might be moving the door around??? its possible. the door is inside the dash under the radio i believe. i have not changed it out. i believe it is a big job to get to access. make sure the "temp ****" works o.k., but if it is cold at low speed, it apparenty works sometimes.
Old Apr 21, 2007 | 10:25 PM
ljones0525's Avatar
ljones0525
Thanks, I may have to make a call tothe Ford Dealer and see what the charge will be. I do not have 2 to 3 days todo it.
Old Apr 22, 2007 | 01:56 PM
ljones0525's Avatar
ljones0525
I will give that a try. Thanks.
Drifter22
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Jun 16, 2011 04:56 PM
Drifter22
1983 - 2012 Ranger & B-Series
Jun 14, 2011 07:40 AM
mmlco
Nov 18, 2010 02:33 PM
pjbonthebeach
2004 - 2008 F150
Apr 14, 2010 04:10 PM
pcbman
Apr 25, 2007 01:08 AM
