Sponsored by: Real Truck
What size torx?
Old Apr 20, 2007 | 06:10 PM
F350-6's Avatar
F350-6
What size torx?
I need to remove the rear seat in my 02 F350 crew cab to put down some sound deadening material. Anyone know what size torx I need?
Old Apr 20, 2007 | 06:21 PM
TNT in Round Rock's Avatar
TNT in Round Rock
let me check when I get home .. I believe it's 50 .. the seatbelts are a smaller size on the sides .. the 4 in the back are the same
Old Apr 20, 2007 | 06:26 PM
F350-6's Avatar
F350-6
I appreciate the help. I'll have to drive 15-20 miles if I'm lucky to get the part so I want to be able to call and ask if they have one. I have a set that goes up to T-50 and its bigger than that.
Old Apr 20, 2007 | 07:02 PM
getnbz's Avatar
getnbz
i think its either T 50 0r T55
Old Apr 20, 2007 | 07:24 PM
F350-6's Avatar
F350-6
It's bigger than a 50. I just can't tell how much bigger. Will an auto parts store have these in stock?
Old Apr 20, 2007 | 07:48 PM
getnbz's Avatar
getnbz
mine did when i needed mine i went and tried then til i got the right size and bought it then must be a T55
Old Apr 20, 2007 | 09:35 PM
TNT in Round Rock
Okay, just checked .. for the front two on the rear seat . .it's a T55 .. for the back two it's a hex nut - 18mm .. behind the seat, there are 4 more bolts for seat belts that are also T55 .. on each side, inside the back door, those should be a T50 .. hope that helps ..
Old Apr 20, 2007 | 09:53 PM
F350-6's Avatar
F350-6
Thanks for the help. I've already gotten out all the 50's and the 18mm, so I'll make some calls tomorrow and see if I can find the T-55.
Old Apr 20, 2007 | 10:55 PM
mcjones44us's Avatar
mcjones44us
I found mine at good old sears. I put 2 layers of dynamat over all the doors & floors of my excursion. Really does help, but it's kind of scary to stare at a bare metal interior and wonder if you'll ever get it all back in again...!
One thing I found; I think the mat I put on the doors actually diminished more ambient road noise than the stuff I put on the floor. Just my experience.
Old Apr 21, 2007 | 08:20 AM
F350-6's Avatar
F350-6
Turns out my daughters boyfriend had a 55 so maybe he's not so worthless after all.
I've read the same thing about the doors in other posts, but I have the carpet delete option on my XLT so I'm hoping for an improvement there too. Since I plan on doing the doors and floor this weekend I guess I'll never know which one helps the most.
Thanks for all the help.
Old Apr 21, 2007 | 09:22 AM
Super08's Avatar
Super08
Funny
Old Apr 21, 2007 | 12:37 PM
emptyd's Avatar
emptyd
I replaced the mid. bench seat in my '01 X with captains chairs. I had to use a 50 for the bench mounts as well as the seat belts. It was sloppy, but the 55 wasn't even close. It was almost like it was an "in-between" size. Any thoughts?
Old Apr 21, 2007 | 11:09 PM
F350-6's Avatar
F350-6
A 55 worked on mine for the seats, and a 50 for the seat belt. It was a little loose but the 60 was too big. I was wondering if it was like a SAE vs. Metric thing, just another set of tools to buy.
KBEDesigns
Jan 4, 2010 04:43 PM
watersurgeon
Apr 18, 2006 10:09 AM
fordfanwv
1983 - 2012 Ranger & B-Series
Dec 31, 2005 10:15 PM
99f350sd
Dec 3, 2003 03:54 AM
Norm Carter
1978 - 1996 Big Bronco
Nov 15, 2003 02:30 PM
