Overdrive button flashes like its new year :S
1990 351W E40D
-when the door is open it flashes in kind of a pattern ( when the car is on )
-when the hazzard are on it flashes the opposite of the hazzard lights
-when i press the brake it comes on press it again it will go off
things iv'e tried
*Full tranny flush 2 months ago
*cleaned the VSS sensor
*any more ideas?
there are two connectors at the trans
clean and check both for full contact
also check all grounds
do you have any drivability issues
read the codes from computer
sensors on the engine can cause issues with the trans
also check out www.fordfuelinjection.com
flashing od can be a code or it can indicate
a bad connection as mine does
I have cut the wire to my trans pressure regulator
and that causes my od lite to flash
no codes in comp. though
