Anyone Running Powerservice?
Old Apr 20, 2007 | 04:40 PM
David85's Avatar
David85
I was in the automotive section of crappy tire the other day and was looking for some diesel fuel additive and found this brand.
Since every source avalable to me is selling low sulfur, I figure I should porbably be running some sort of fuel lubricant supliment. I tried ATF($$), and two stroke oil, but I was wondering if powerservice is worth trying. I can't be sure, but I think there was a slightly better performance in terms of fuel economy when I was running 2S oil.
Now I'm sure there are claims out there that some fuel aditive can increase fuel economy, but have any of you had any experience with this?
Old Apr 20, 2007 | 04:48 PM
fonefiddy's Avatar
fonefiddy
I've been running Power Service for 3 years or so. 4 oz's per tank. It's been so long, that I can't remember if it actually does anything or not.
But I run #2 up here all the time. Never had a problem, even @ -30 degree's.
Old Apr 20, 2007 | 05:01 PM
PLC7.3's Avatar
PLC7.3
I use PS silver bottle or Hayes diesel treat...... I find Hayes (cheaper) helps lubricate and my truck runs very nice........the PS gives it a little more cetane and causes black smoke on heavy pulls.
Hayes can be found at truck stops or IH dealers........
Crappy Tire............He He He.... we Canadians give ourselves away EH!!
Old Apr 20, 2007 | 07:21 PM
bluthunder's Avatar
bluthunder
I started using PS one month ago. Noticed a difference with the first tank of fuel. Smoother idle, quicker starting, little better accelerator response.
Old Apr 20, 2007 | 08:24 PM
2jhanna's Avatar
2jhanna
I replaced the IP on our F450 last year. The rebuild shop that I got the IP from, said that for the warranty to be effective, I would have to change the fuel filter routinely and use 1 of 3 recommended additives. I don't remember the other 2, but Power Service was 1 of them. I also, put 4 ozs per tankfull.
Old Apr 20, 2007 | 09:26 PM
David85's Avatar
David85
Yeah I guess we do
Well I guess I try will the stuff, its not very pricy, and with only 4oz per tank, what the heck.
The truck already runs like a top, and drives like a beast since I put the turbo in, but I don't want to deal with premature injection system wear.
Old Apr 20, 2007 | 09:34 PM
2jhanna's Avatar
2jhanna
It comes in a white bottle and a silver/gray bottle. Quarts and gallons. I forget which, but 1 is for winter use, anti-gel. Most parts stores have it and Wal-marts around here.
It has also been stated several times on this forum, to fill your fuel filter with it as you change it.
Old Apr 20, 2007 | 10:24 PM
CheaperJeeper's Avatar
CheaperJeeper
Hmmmn, at 4 oz per tank it seems to me that you folks are mixing it a bit light.
Let's do the math; 19 gal x 128 oz per gal = 2432 ounces of fuel
divide that by 4 ounces and you're mixing it at a ratio of 608:1
To raise cetane 6 points or for injector & pump cleaning PowerService recommends mixing it at 200:1 (3 times more than you're using). To raise cetane 3 points and for regular pump & injector lubrication the bottle recommends a mix ratio of 400:1 (1.5 times what you're using).
I mix mine at 1 ounce per 3 gallons which is 384:1 (3 x 128 = 384).They don't actually sell it by the gallon around here - it comes in a 96 ounce (3 quart) bottle that costs $15.20 + $1.34 in sales tax at WallyWorld.
At $16.54 for 96 ounces the cost is 17.23 cents per ounce, and since an ounce treats 3 gallons I figure using PowerService adds 5.75 cents per gallon to my fuel costs. At less than 6 cents a gallon I'll have to burn 10,435 gallons of fuel to equal the $600 cost for a set of reman injectors & a pump.
At an average of 15 mpg that would mean driving over 155k miles before I'll spend as much on PowerService addative as I would on a pump & injectors.
Seems like pretty cheap insurance to me, so yeah, I use it.....
Old Apr 21, 2007 | 01:05 AM
David85's Avatar
David85
Is there really an advantage in having the cetane level in the fuel boosted?
Old Apr 21, 2007 | 07:29 AM
fonefiddy's Avatar
fonefiddy
Yes, it ignites faster, and produces more heat.
I don't actually measure it. I have it down to 3 'Glugs' and I can get about 6-7 tankfulls out of a 1 quart bottle.
I think some peeps are waaaaay over reacting with the ULSD. The refiners are saying that the lubricity package added to the fuel is actually more slippery than LSD. Seeing as the DB2 pump uses Viton seals, and our Inj's have NO internal seals. The only thing that can be effected by the lower sulfer fuel is the return o-rings. Which are easily maintained.
I've NEVER had a problem. I've been useing ULSD all winter.
Old Apr 21, 2007 | 08:15 AM
2jhanna's Avatar
2jhanna
thanks, jeeper, i hadn't did the math. but, you are correct, i should be using more. it is cheap insurance.
Old Apr 21, 2007 | 12:27 PM
CheaperJeeper
Well, if following the recommendations on the bottle is over reacting then sure, mea culpa.....
Having had the pump fail just a couple of months after buying the truck from a PO who DIDN'T use addatives, I did the math and came to the conclusion that I didn't have much to loose by using it and mixing it at the ratio recommended on the bottle....
