1978 - 1996 Big Bronco
Suspension
Old Sep 19, 2001 | 08:43 AM
95fordbronco302's Avatar
95fordbronco302
Suspension
I have develope a clunk and a clinking noise near front of the truck. I checked my tie rod ends and ball joints and they seem fine. I suspect that it could be the radius arm bushings. It happens when backing up and if I am driving and apply the brakes to slow down to a stop. Thankyou in advance for any suggestions.
Old Sep 19, 2001 | 11:24 AM
brents's Avatar
brents
Suspension
Hi,
Yup, sounds to me like the radius arm bushings are shot. Common problem on these trucks.
-Brents
Old Oct 19, 2001 | 12:27 AM
Riso79's Avatar
Riso79
Suspension
Mine does the same thing. ANd my radius arm bushing are brand new. I think that it is my tie rod ends, i thought it was the coils rotating, because mine generally does it when the wheel is turned. Have you fixed it yet?
Old Oct 19, 2001 | 10:56 AM
95fordbronco302
Suspension
Replaced both sides and fixed my problem. The bushings on the drivers side where shot. I did some research and found in some cases that loose rivets can also cause clicking and banging noises. Hope it helps.
Old Oct 19, 2001 | 08:00 PM
Franklin2's Avatar
Franklin2
Suspension
Jaime74656
Dec 25, 2015 08:53 AM
j4henry
Jan 19, 2012 08:44 PM
aloonda
New Member Introductions
Sep 19, 2004 08:19 PM
krazdndenver
Sep 21, 2002 07:06 AM
leward
Jul 11, 2002 09:18 PM
