Chevron 400 LE Oil
Old 07-20-2014, 11:15 AM
lhud's Avatar
lhud
lhud is offline
Chevron 400 LE Oil
OK, I have been running the Rotella T6 for some time with good oil analysis. However, after approx. 2k to 3k the oil starts turning black - not like the honey colored when installed.
Recently I have tried the Chevron 400 LE full synthetic and it will stay the honey colored until approx. 7k when I need to add another two quarts. I just got a good oil analysis back at 10k and it is a little discolored but certainly not dark in color as compared to the T6 at the same mileage.
I am just wandering if any of you guys have noticed the same thing - not that it is causing any problems, just wandering what technically might be causing this change in color.
This is not intended to start an "oil debate".
Thanks guys,
Old 07-20-2014, 01:48 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
No explanation but I run Dino Delo and my Stroke loves it.
Old 07-20-2014, 05:33 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
My truck has run DELO 400 15w-40 - not LE - since it was new with 3-4K OCI and is still amber in color at change time. Just my $.02.
Old 07-20-2014, 07:10 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I'll investigate. The reason oil turns black is because its doing its job. Its picking up the ash and moving it. Diesels create lots of soot and that's why our oil goes dark so fast. Black oil is not bad oil in a diesel.
Some trucks produce less ash and their oil stays amber longer but I wouldn't think an oil would pick up less than another.
Did you change filters? What filter are you using?
Old 07-20-2014, 10:59 PM
clem1226's Avatar
clem1226
clem1226 is offline
Where are you buying the non LE delo ? I haven't seen any on the shelves in years.
Old 07-20-2014, 11:41 PM
hydro man 17
Clem, I have my oil changed at a local independent lube service - ( not minimum wage kids ). They have it in bulk as well as the LE stuff. I believe that the local NAPA store stocks it as well, but we are an almost dead logging town so lots of older trucks in the area.
Old 07-21-2014, 09:01 PM
petrokiller
Ok I use the LE also. Just had to look in the garage. Grab mine at Costco or Oreilly's.
The Carpathia
32
02-02-2012 11:07 AM
Kenworth
08-03-2009 09:56 PM
TayzGpa
28
10-09-2007 11:37 AM
mahause
06-05-2007 12:03 PM
watermanh
09-11-2005 02:00 PM
Quick Reply: Chevron 400 LE Oil
