oil pan
Old Apr 18, 2007 | 10:53 PM
rusty7983's Avatar
rusty7983
oil pan
i have me a 77 f350 it now has a 78 460. i did an oil change the other night and the drain plug is centered on the engine crossmember. what type of oil pan should this truck have? rear sump? is this the correct style pan? shouldn't the drain plug access be easier? thanks y'all.
Old Apr 18, 2007 | 11:19 PM
1977Ranger250's Avatar
1977Ranger250
my 77 with the original 400 engine has the same thing, oil drain plug right above the crossmember, makes for a messy oil change
Old Apr 19, 2007 | 12:04 AM
70blue's Avatar
70blue
Maybe something like this would help. http://www.lubricationspecialist.com...FQ4egQodrR7T_Q
Old Apr 19, 2007 | 12:08 AM
ihateminimumwage's Avatar
ihateminimumwage
That's just how it is I believe. My 79 is 4x4, so it's away from the axle, but my 360 in my 2wd 70 would drain out, and soak everything on the way to the tray...
Old Apr 19, 2007 | 12:43 AM
Broken40's Avatar
Broken40
My ford doesn't have that issue, my drain plug is about 1ft maybe 1ft 1/2 away from my crossmember....lol. Man that's messy.
Old Apr 19, 2007 | 12:50 AM
Torque1st's Avatar
Torque1st
Posting Legend
On my 400 I had a piece of 2" PVC pipe cut at an angle that I would jam in under the pan. I could stick a long extension thru it and pull the plug. It made for a much cleaner oil change since the pipe conducted the oil out to a drain pan.
Old Apr 19, 2007 | 12:58 AM
Broken40's Avatar
Broken40
sweetness, that's not a bad idea, man i thought of some pretty wicked ideas in my time but that's by far a really good idea.
Old Apr 19, 2007 | 12:54 PM
Mil1ion's Avatar
Mil1ion
I drilled a hole and welded in a nut for front drain hole in a front sump pan.
I can drain the oil without hardly crawling under the truck at all.
The oil pan you have on that engine is from a car.
Old Apr 19, 2007 | 10:56 PM
rusty7983's Avatar
rusty7983
dennis, can i get a truck one and make my life easier? would the plug be more accessable? thanks
Old Apr 19, 2007 | 11:39 PM
Mil1ion's Avatar
Mil1ion
Yes, From an E-series Van for rear sump and from a 83 & up F-series 460
Old Apr 20, 2007 | 12:05 AM
Torque1st's Avatar
Torque1st
Posting Legend
Even tho I had the pipe cut like above when I pulled the pan to do some bottom end work I put a drain plug in the front corned of mine also. It probably leaves a bit of oil in the pan due to the engine tilt but seems to be good enuf. Now I can just reach under and change the oil and filter without jacking the truck up and crawling underneath.
Old Apr 20, 2007 | 12:33 AM
Jermafenser's Avatar
Jermafenser
I think the 4wds got the clean-flow oil options. My Bronco didn't leave a mess when changing oils. My 2wd pickup always make a spill on the crossmember.
Torque, you must be a helluva big guy if you have to jack it up. I could slip underneath easily under my 2wd pickup.
Old Apr 20, 2007 | 01:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
6'4" 230#. I may be able to squeeze my sternum under that greasy F250 crossmember but that is nothing I want to do. With my luck one of the tires would pick that moment to deflate. No way I can get at it from the sides either due to the running boards. I used to just jack it up with the floor jack and support it with a couple jack stands. At my age I no longer want to crawl under at all...
Old Apr 20, 2007 | 01:41 AM
rodbuildingfool's Avatar
rodbuildingfool
My 76 with a 300 is the same way plug right on top the crossmember not that big of mess though till stream starts to weaken then gets everywere. i think wlamret sold those drain plugs that you could put a tune on and turn valve and it would come out the tube maybe one of those would work. If anyone knows what im talking about.
Old Apr 20, 2007 | 01:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975/89 Econoline 460
E7UZ-6675-A .. Oil Pan~Rear sump (E7UZ-A replaces E6UZ-A / D5UZ-A)
E4UZ-6622-A .. Pickup Tube~Rear Sump (E4UZ-A replaces D5UZ-A)
D9HZ-6345-A .. Stud: 3/8"-16-1/2" -16 x 4 7/8" ~ mounts oil pickup tube~use with rear sump oil pans.
