1980 F150 Transmission problems
Old Apr 18, 2007 | 09:51 PM
bigjoejimbob's Avatar
bigjoejimbob
Red face 1980 F150 Transmission problems
I have a 1980 Ford F150 ranger that is an automatic 4x4 pickup. The other day I was changing the front tires on it. When I went to jack-up the right side, I didn't have the jack centered right and the truck slipped off the jack after the wheel was 3-6 inches off the ground, thank god the lug-nuts were not loosen to much yet. Anyways after I got the tire changed I took the truck for a ride and that is when I discovered my screw-up. The auto-transmission did not want shift thru any of the gears in auto. But if I would manually shift it, it would shift between 1st and 2nd fine, but between 2nd and 3rd sometimes it would and sometimes it wouldn't shift. I am not certain what is causing this, so anything that you guys can think of to help me solve this problem I would appreciate.
Old Apr 19, 2007 | 12:25 AM
Franklin2's Avatar
Franklin2
Check your vacuum lines, and especially the one that goes from the back of the intake manifold down to the rear of the tranny. It should have a vacuum line near the tailshaft area too.
Old Apr 19, 2007 | 09:08 AM
Redneck1465's Avatar
Redneck1465
I agree with Franklin2, I had the same problem and was able to remedy this by reconnecting the vaccum line from the intake to the transmission.
Old Apr 19, 2007 | 01:00 PM
bigjoejimbob
Ok found the vaccum line at the transmission had a big crack in it, can I cut it off, cause the crack is right were it hooks into the trans mission or do I need a new line??
Old Apr 19, 2007 | 04:34 PM
Franklin2's Avatar
Franklin2
That's your judgement call. If one end cracked, it must be old and the rest of it is probably at the end of it's useful life. But if it looks ok, you can certainly cut it off and try it.
Old Apr 19, 2007 | 07:15 PM
bigjoejimbob
Well at .40 cents a foot for new vaccum tube, I think I can afford to replace it. Thanks for the help!
hooperdoski
Jan 7, 2013 09:55 AM
Meat_fire
Feb 2, 2008 06:02 PM
06escapefan
Escape & Escape Hybrid
Feb 1, 2006 09:11 AM
moman
1966 - 1977 Early Broncos
May 2, 2002 10:23 AM
