Extra reverse lights
Old Apr 18, 2007 | 12:22 PM
just another truck's Avatar
just another truck
I was going to hook up some lights on lunch today, have everything mounted, just need to know if anyone can tell me what wire to tap off of from the trailer wire harness? Hoping to wrap it up after work today, if not, there is always tomorrow. Thanks, and if I figure out how to post pictures, I will show the end result.
Old Apr 18, 2007 | 01:12 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
The trailer harness (factory 7-pin connector) should tell you the correct wire for back-up lamps. I wired in a lamp for mine a couple months ago, did not have the factory connector, found the correct wire with a 12v probe that you poke in the wire. Hope this helps.
Old Apr 18, 2007 | 01:15 PM
wlihntr's Avatar
wlihntr
on the trailer plug the back up lamp wire is; black/light green
Old Apr 18, 2007 | 01:22 PM
travis dasher's Avatar
travis dasher
Why not just tap into the reverse lights in your taillight, that way you can still hook up a wiring harness when towing and still have the reverse lights. But then again if you have a trailer hooked up you wouldnt see the reverse lights anyways.
Good answer..... haha
Old Apr 18, 2007 | 01:33 PM
John311t's Avatar
John311t
Okay, here is how ya do it.
https://www.ford-trucks.com/forums/5...with-pics.html
You need a diode for something, which reminds me i need to go buy a diode for my headlights.
just another truck
I was planning on splicing in, so I would still have the trailer light option ( if the trailer has reverse light ).
Thanks guys, I had left the manual at home, wanted to wrap this up before I got there.
Old Apr 18, 2007 | 01:36 PM
just another truck
Thanks John, by the way, saw your gallery, if a F-250, cap on, flashes his head lights at ya, you know why. I am about 8 mile south of you.. Didnt want to go that far yet, thats why I was just tapping to the wiring in the back.
Old Apr 18, 2007 | 01:44 PM
John311t's Avatar
John311t
I work in sterling heights, so im sure ill see ya one day. Every week it seems like more MI guys are comin on here.
Old Apr 18, 2007 | 05:13 PM
wlihntr's Avatar
wlihntr
diodes????...you dont need no stinking diodes....lol just tap into the trailer back up wire,its fused at 20 amps so it can handle 2-55 watt lights (in fact even more) and what ever back up lights would be on a trailer
Old Apr 18, 2007 | 06:20 PM
cangim's Avatar
cangim
It is the center wire for a 7 pin RV plug, the color is Black/Light Green stripe, Yellow is industry standard on trailer side.
<TABLE style="WIDTH: 325pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=433 border=0 x:str><COLGROUP><COL style="WIDTH: 48pt" width=64><COL style="WIDTH: 91pt; mso-width-source: userset; mso-width-alt: 4425" width=121><COL style="WIDTH: 93pt; mso-width-source: userset; mso-width-alt: 4534" span=2 width=124><TBODY><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 48pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" width=64 height=24>Pin</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 91pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=121>Func.</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 93pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=124>Ford</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; WIDTH: 93pt; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" width=124>RV</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Ground</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">White</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">White</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>2</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Brake</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Blue</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Blue</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>3</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Tail/Running</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Brwn/White</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Green</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>4</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Charge +</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Orange</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Black</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>5</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Left/Stop</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Yellow</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Red</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>6</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Right/Stop</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Green</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Brown</TD></TR><TR style="HEIGHT: 18pt" height=24><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 18pt; BACKGROUND-COLOR: transparent" align=right height=24 x:num>7</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Aux/Back UP</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">BK\LG</TD><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Yellow</TD></TR></TBODY></TABLE>
Old Apr 19, 2007 | 11:58 AM
just another truck
Well, yesterday I hooked up the lights, adjusted it, everything was beutiful, this morning, got to work, some guy was in a ditch, backed up to him, put the truck in park, walked back and said" damn, wouldnt it be nice if I had a switch on those" at lunch, switch is complete.
Old Apr 19, 2007 | 12:01 PM
just another truck
The use of the diode is protect the existing circuit when you flip the switch on. Not sure you need it though, because the power source is the same, and there is a relay there. Have to check the book again when I get home.
Old Apr 19, 2007 | 01:29 PM
John311t's Avatar
John311t
wlihntr
Lol, i was talking about a diode for my front headlights so that i could get the highs and lows to stay on at the same time.
Old Apr 19, 2007 | 01:34 PM
just another truck
Let us know how that works....
Old Apr 19, 2007 | 02:41 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
wlihntr
Brite Box does it for you.
