trouble codes
Old Apr 17, 2007 | 06:52 PM
greenterror's Avatar
greenterror
Question trouble codes
02 explorer abs light went on the battery light,the wipers started to slow down all guages stopped working,finnaly the truck started bucking then stopped.is this the alternator? need help thanks
Old Apr 17, 2007 | 08:04 PM
steve(ill)'s Avatar
steve(ill)
sounds like a good bet. do the head lights work? will the starter crank over? if the alternator stops working, you will run off the battery til it goes dead. you should see the voltmeter needle low if the alternator is the problem.
Old Apr 18, 2007 | 09:35 AM
aquanaut20's Avatar
aquanaut20
Put a volt meter across the battery terminals, sitting battery voltage should show 12.0-12.5vdc, running you should see about 14.2vdc.
