98 explorer servicing
Old Apr 17, 2007 | 03:32 PM
crandell85's Avatar
crandell85
7th Gear
I've a 98 explorer 4x4, 4.0L, automatic<O:p></O:p>
A number of years ago when I purchased this vehicle new, I was given a print out of the dealer recommended servicing schedule<O:p></O:p>
Inspection at 100,000 km and 200,000 km<O:p></O:p>
<O:p></O:p>
Special operating conditions and other services.<O:p></O:p>
<O:p></O:p>
Op code: 132P replace fuel filter every 20,000 km. under special operating conditions.<O:p></O:p>
Op code: 10P off road service every 20,000 km. ( inspect , clean , lube underbody, linkages, vents and brakes)<O:p></O:p>
Op code: 870P Change Automatic Transmission fluid every 200,000 km. ( 50,000 under special operating conditions)<O:p></O:p>
Op code 228P Replace rear axle lubricant every 250,000 km. (100,000 km under special operating conditions)<O:p></O:p>
Op code 5P Replace front axle lubricant every 250,000 km. ( 100,000 km under special operating conditions)<O:p></O:p>
Op code 190P Replace PCV valve every 150,000 km. ( 100,000 km under special operating conditions)<O:p></O:p>
Op code 199P Replace platinum spark plugs every 150,000 km. ( 100,000 km under special operating conditions)<O:p></O:p>
Op code 8P Replace transfer case fluid every 250,000 km. ( 100,000 km. under special operating conditions)<O:p></O:p>
Op code 275P Replace Accessory Drive Belt every 200,000 km.<O:p></O:p>
<O:p></O:p>
<O:p></O:p>
The vehicle has been maintained according to the severe conditions schedule as listed in the <O:p></O:p>
owners manual on servicing. The vehicle is mostly city driven but has been <O:p></O:p>
used off road for 15% of the total mileage.<O:p></O:p>
<O:p></O:p>
I wondering if those out there would agree with the dealer schedule.<O:p></O:p>
I am now coming up at 145,000 km and anticipate the 150,000 km service.<O:p></O:p>
<O:p></O:p>
Do you think the called for 150,000 km changes should be done at that time<O:p></O:p>
<O:p></O:p>
Old Apr 18, 2007 | 09:45 AM
aquanaut20's Avatar
aquanaut20
Originally Posted by crandell85
I've a 98 explorer 4x4, 4.0L, automatic<O></O>
Op code 190P Replace PCV valve every 150,000 km. ( 100,000 km under special operating conditions)<O></O>
Op code 199P Replace platinum spark plugs every 150,000 km. ( 100,000 km under special operating conditions)<O></O>
The vehicle has been maintained according to the severe conditions schedule as listed in the owners manual on servicing.
If I read you correctly, you have performed the service a 100,000km, so no there would be no need to do it again at 150,000km.
Should you have drivability issues or a drop in fuel economy(if there is such a condition with an EX) then this service would be in order at any time.
gastelumri
Escape & Escape Hybrid
Sep 24, 2015 05:37 PM
bismic
Aug 10, 2015 10:35 AM
Bob 79 supercab
Aug 7, 2015 10:33 PM
jpj64
1983 - 2012 Ranger & B-Series
25
May 24, 2010 08:58 PM
Vesa Mikkonen
Projects
Jan 9, 2009 01:36 PM
