Payload and Towing Capacity?
Old Apr 17, 2007 | 04:36 PM
blue ox's Avatar
blue ox
First time poster with a lot of questions....
I have a 1990 F-350 crew cab 4x4 with the 460 EFI engine / E4OD tranny. It has a 3:55 limited slip rear diff with single wheels and a long bed. The rear end is a Ford 10.25 Sterling with a Dana 60 monobeam front axle. I can't find a copy of the Ford Trailering Guide online anywhere. Can anyone tell me the max towing for this setup and the max payload for the bed? It already has a Reese CL V hitch, anti-sway bar and Tekonsha brake controller. I was wondering what would be the max weight of a travel trailer I could pull (hitch mounted, not 5th wheel).
If I went with a camper-style setup, what would the max allowable weight be?
The most I have had in the bed so far was 20 railroad ties for landscaping. The only time it rode smoothe, by the way. Otherwise, like riding in an old conestoga wagon on a trail...
Also, is 10mpg normal? I would hate to see what it gets when I pull something with wheels rather than unwanted trees out of the ground!
I am kinda attached to it as I only paid $2K for it from a repo place.
Thanks for any input!
Old Apr 17, 2007 | 05:52 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
In my 93 manual which should be close. Max GCWR is 11500 trailer weigh of 5700. The gross vehicle weight rating should be on the tag on the door jam (example GVWR 7700). You will have to weigh the truck empty to find out what the max would be by subtracting that # from the GVWR.
Old Apr 17, 2007 | 06:32 PM
stryder's Avatar
stryder
GVWR should be about 9000lbs for a single wheel F350 with your setup. Like mentioned, its on the tag located near the strike plate on the drivers door. Figure about 5400lbs for the truck weight fully fueled and you in it. That would leave approx. 3600lbs legal payload capacity.
Old Apr 18, 2007 | 04:21 PM
rclarke's Avatar
rclarke
The GCWR for the 3.55 axle, 7.5 engine, and crewcab is 15,000lbs. Max tow is 9100lbs.
Old Apr 18, 2007 | 06:09 PM
Leader's Avatar
Leader
The "Legal" payload has nothing to do with the Manufacturers suggested Gross Vehicle Weight Recomendation. It DOES have to do with what you register the truck at. Get 6000# plates in IN and you will be overweight empty. If you get into an accedent some here say your insurence will not pay & you will be sued & go to jail.Get 26000# plates and you can load 20000#'s in the box & be *Legal*. Safe is another question....But according to the people here... "Legal" means you can't be sued & will not go to jail if you kill somebody.And your insurence will pay all costs no matter what limits or coverage you have.
Old Apr 18, 2007 | 08:01 PM
jake00's Avatar
jake00
true <filller>
Old Apr 19, 2007 | 09:50 AM
blue ox's Avatar
blue ox
Yes,
GVWR is 9200, with front 4600 and rear 6084. But what is the CGVWR? That takes GVWR and tells you what the max towing capacity is... I have a 37 1/2 ft 8900 lb trailer (dry) and it is 9,500 wet (water, propane, accessories...). With clothes, gear, etc.. it is around 11,000. Is that too much?
Ox
Old Apr 19, 2007 | 12:08 PM
bigredtruckmi
Veteran: Navy
By the specs - Yes it would be too much but if you don't mind slow going and if you have no mountains then it would be a ??.
Old Apr 19, 2007 | 02:31 PM
Leader's Avatar
Leader
According to Edmunds.com the Max Towing is 12,500#'s with a 5.8L engine.
Yes your truck will pull that trailer.
Old Apr 19, 2007 | 06:38 PM
bigredtruckmi
Veteran: Navy
Please send link. I was unable to locate towing ratings on edmunds.com i was going to bookmark it. Thanks.
Old Apr 20, 2007 | 04:02 AM
Leader's Avatar
Leader
http://www.edmunds.com/used/1990/for...412/specs.html
We disagree on the value of this spec but here it is.
Old Apr 20, 2007 | 09:49 AM
jimandmandy's Avatar
jimandmandy
I belive that Edmunds figure is a "maximum", with all available options, not standard equipment. So, the 460ci V-8 and E40D with 4.10 gears can easily pull that amount. Since you have 3.55 gears, subtract maybe 1500 and that still gives you 11,000lbs.
10mpg is normal for that rig and expect less with a heavy trailer attached. That is why diesels outsell gas engines today in Super Duties.
Jim
Old Apr 20, 2007 | 11:52 AM
Leader's Avatar
Leader
Jim
Is that because you didn't go to the website & actually see what it said?
It was for a truck with a 5.8 L (351CI) engine.
Old Apr 20, 2007 | 12:59 PM
rclarke's Avatar
rclarke
These numbers come from the Ford Towing Guide. The numbers listed on Edmunds.com are absolute maximums for 5th wheel towing with 460 and 4.10 gears. The Edmunds numbers don't apply to the truck that the original inquiry was for.
Old Apr 20, 2007 | 01:12 PM
Leader's Avatar
Leader
Really ??? Then why does it CLEARLY list the engine as a 5.8 liter ???
And just what is going to happen if you go over this magical weigh ?
