Power Sliding Rear Window
I have a '06 F150 SCREW with the power rear window. All was quiet until the vehicle clocked approximately 20k miles. Now, when closed, it seems to squeak constantly. The squeaking ceases as soon as the window is cracked open. Anybody else have a similar problem, and is there a known cure (besides riding with the window open all of the time ) ?
Try putting dry graphite on the run channels that the glass slides in and also where the glass meets the divider between the stationary glass and the movable glass. Most likely the movable glass is rubbing on the rubber that is between the two glass panels and when you open the slider it isn't rubbing anymore.
I had the same issue and I've had the dealer look at it twice now. There is a TSB out there for the issue, so as long as its under warranty its covered. Unfortunately I don't feel that the Ford fix has done much to help but its better than it was. Take it to the dealer with a copy of the TSB (search the TSB list on this site for power rear window) and they'll fix it free of charge.
Thanks for the info, folks. Good to know I am not the only one. Will have it checked out at my next service interval (~2 weeks).
I searched 2004 - 2008 TSBs and could not locate the power rear window TSB. Did I miss something?
