Predator boost #'s
Old Apr 17, 2007 | 02:10 PM
77hiboyboy's Avatar
77hiboyboy
Predator boost #'s
Those who run the diablosport predator what kind of boost #'s are you getting on WOT?? On heavy WOT I can get 25lbs once I get into a big gear that lets me load the motor down enough to let it pull. Just curious on what everyone else was pulling with that tuner.
Old Apr 17, 2007 | 02:26 PM
Kwikkordead's Avatar
Kwikkordead
I just posted this picture in a different thread as well.
I was coming back from vacation and climbing out of the Columbia river gorge with the CC on, the wastegate connected and in high gear going 65 mph up a long gentle grade. Maybe 2-3%.
Diablo Predator Tow/Haul tune loaded.
Old Apr 17, 2007 | 02:28 PM
Kwikkordead
Yes the turbo was screamin' and yes I was nervous.
Old Apr 17, 2007 | 02:39 PM
77hiboyboy's Avatar
77hiboyboy
I might have a small leak, but I guess I'm not that far off though either. Thanks.
Old Apr 20, 2007 | 05:26 PM
Jakeman68's Avatar
Jakeman68
Diablosport predator here. In the 100 HP setting I can get it to hit 25 to 27 psi. Loaded with a trailer I can hit 32 psi if I am not careful.
Old Apr 20, 2007 | 10:35 PM
Tecman's Avatar
Tecman
with mine I could not get over 20#s empty. I couldnt really get any higher towing my 4500# trailer either. I just installed my DP tuner and hit 24#s real easy unloaded.
Old Apr 21, 2007 | 09:34 AM
Kwikkordead
Tecman you must have an air leak somewhere. That picture that I took was on the Tow/Haul mildest tune that Diablo has with the wastegate connected.
With a DP you should be able to peg your 30# boost guage.
Old Apr 21, 2007 | 03:28 PM
Tecman's Avatar
Tecman
I have my guage hooked up to my MAP sensor, could that read a different reading than having it taped in somwhere else?
I will go over all my hoses today checking for any leaks.
Old Apr 21, 2007 | 06:57 PM
Kwikkordead
Got a boost pressure relief valve on the MAP hose?
That will effect the number.
Old Apr 21, 2007 | 07:03 PM
Tecman's Avatar
Tecman
I have a reg from ITP. Im tapped in between the manifold and the reg. Other than the AIH, where is the most accurate place to tap a boost line?
Old Apr 21, 2007 | 09:35 PM
Kwikkordead
That one doesn't bleed pressure and where you have it is accurate.
Old Apr 22, 2007 | 01:09 PM
crack's Avatar
crack
I must havea boost leak, I never see more thant 22 psi. I held it in 5th around 3200 rpm and got 25 but my egts were up around 1400.
Old Apr 22, 2007 | 01:49 PM
Kwikkordead
Is your wastegate disabled?
Old Apr 22, 2007 | 02:54 PM
crack's Avatar
crack
I usually run it disabled yes, but I hooked it up the other day after seeing that you got 27 with it connected...and I could only manage 21 or so with it connected.
Old Apr 22, 2007 | 04:58 PM
Kwikkordead
That was pulling 24k up a hill with CC on. Engine was at WOT for a couple of minutes .
