Fuel leak?
Old Apr 17, 2007 | 09:05 AM
TQ29m's Avatar
TQ29m
Fuel leak?
Hello, Newbie here, just aquired my 1997 F350 PSD. Got a couple questions early on. I seem to have a fuel leak after shut down, maybe 2-3 oz, drips off the flywheel cover, doesn't leak while running. The fuel filter was changed before I bought the truck, and I'm wondering if that could be the problem. Runs fine otherwise, cranks a little after setting 3-4 hrs, but otherwise starts as soon as the light goes off. Also have an oil leak, somewhere on the drivers side, about the center of the wheel well, not real severe, but enough to drip 3-4 drops whenever you stop, and set a while. Valve covers look ok, power steering had oil present in top of cap, but it seems lower than that. This truck has 377k on it, but drives out fine, and so far, everything still works. Any help would be appreciated. Also, need to replace headlite switch shaft and ****, can MapQuest be used to find a route to the release button? Thanks
paulietools
May 25, 2009 08:05 PM
olboney17213
Mar 4, 2009 07:41 AM
JM5034
Mar 17, 2007 03:00 PM
Dustin_86
Aug 8, 2006 09:48 PM
