SMF ZF question
Old Jun 26, 2007 | 10:00 PM
  #46
Brimmstone's Avatar
Brimmstone
Actually I'm lucky with my truck as it already had a SMF flywheel in it. I'm just fixing some problems that have cropped up other wise I wouldn't even be changing the flywheel. I have an intermittent shudder like the flywheel has high spots in it. I figure a new flywheel and upgrading to the 12 inch clutch will make most of problems go away. I'm going to stick with the four speed for about a year then depending on funds, how the truck is running, and my mood I'll either pop in a ZF or I might get lucky and stumble across a 6 speed to put in the truck.
Old Jul 6, 2007 | 10:10 PM
  #47
Dave Barbieri's Avatar
Dave Barbieri
Originally Posted by CheaperJeeper
Well, I got it installed to the point where it is sitting on the tranny mount, on the crossmember on Saturday. Took the family to a Mariner's game yesterday (little league night at Safeco field) so I haven't made any more progress since then. I did get the slave cylinder installed too. Everything looks really good - TOB fork is where it should be etc. I'm confident at this point that it is all gonna' work out A-O-K.
Unfortunately I'm traveling on business this week and won't get a chance to finish up the job until next Saturday
Well, my stuff arrived Thursday. Looks like pretty good quality stuff - the disk is made by Valeo, the TBO is Torrington, and the PP is a FENCO reman unit. I have the third week of August off, so I'll be doing the swap then.
Ya know, the driveline shop tells me there's a 'hybrid' u-joint available. One set of trunnions is the right size to fit the output shaft on the ZF; the other two trunnions are smaller to fit the driveline yoke that's currently installed. I noticed that my carrier bearing can be moved about 1", and last Summer when I tried this for the first time, we only removed about 3/4" from the driveshaft. Sooooo, I'm wondering if I really need to modify the driveline???
Old Jul 6, 2007 | 11:08 PM
  #48
dwkremer's Avatar
dwkremer
I have a LUK SMF in my 91 7.3 ZF and it works fine, no chatter, no noise.
Someone mentioned putting 30weight oil in the ZF. Keep in mind that ATF is used in ZF because its gear toleraces are so close that a heavier weight oil could squish out and leave the gear dry. The ATF in the ZF should be changed on a regular basis, just like an automatic.
Old Jul 7, 2007 | 12:18 AM
  #49
catfish101's Avatar
catfish101
[/QUOTE]
There are several joints out there with two different sizes trunnions. I am thinking a common one that is used is a "434" Napa number. Two sizes on a joint isn't uncommon anymore.
I used a joint like this when I put a 205 transfer case out of a 79 model in my 95 chassis and I used the half ton front drive shaft. I had a joint that would fit the old slip yoke and the big end fit the 50 IFS yoke. The joint was in a "434" Napa box but I can't be for sure that it was in the right box. I have had the joint for years and it just happened to work. The big side of the joint is 1.126" and the small side is 1.064".
Old Aug 26, 2007 | 06:29 PM
  #50
Dave Barbieri
CJ -
How did your tranny swap end up? (inquiring minds wanna know....) I'm looking at starting mine the week after Labor Day. Got all the pieces/parts, but now I need to take care of a coupla oil leaks first.
Old Aug 26, 2007 | 07:56 PM
  #51
CheaperJeeper's Avatar
CheaperJeeper
Originally Posted by Dave Barbieri
CJ -
So far so good. I have a couple of engine leaks I need to track down and fix myself.....
Old Aug 26, 2007 | 09:40 PM
  #52
Dave Barbieri
So far so good.
How about tranny noises? Any clattering/rumbling?
That's what nailed me last Summer when I tried this for the first time. Scared the crap outta me. I thought tranny parts were about to start a relay race across the shop! Well, a coupla weeks ago, I was at a training class on manual transmissions, and one of the instructors commented on how common it was for the 5th gear bearing to go out on the ZF's. Said you'd hear this horrible rumbling noise in all gears but 5th. In 5th gear, the bearing doesn't rotate, since the gearset is locked to the shaft. Man, it was like a giant spotlight went on over my head! So, now that I'm back, one of the first things we're doing this week is pulling off the rear case and checking out that bearing. It'd be too cool if that's what the problem was!
Old Aug 26, 2007 | 10:02 PM
  #53
CheaperJeeper
There's still some gear rattle at low RPMs, but not too bad. Nothing I'll have any problem living with....
7.3 forever
58
Aug 15, 2017 06:02 PM
Pheadrus
16
May 11, 2016 07:55 PM
Troyus
Feb 15, 2016 06:54 PM
King7765
22
Dec 23, 2015 10:42 PM
joeruger509
Nov 12, 2015 10:16 AM
