leaf springs
Old Apr 16, 2007 | 09:43 PM
dadstruck's Avatar
dadstruck
leaf springs
Well my 66 project has a five leaf spring package. No wonder the thing was such a wimp when i used to load it with wood etc. Rear of the truck used to sag a little. New springs are not an option at this time. That money is budgeted for a new fuel tank and sender. Has anybody tried the add a leaf springs or would you recomend a salvage six leaf set if I can find them.
thx.
Old Apr 16, 2007 | 10:15 PM
onepeiceatatime's Avatar
onepeiceatatime
i do not know what some of the others on here will say but my 62F100 has a totall of 13 leafs on the rear and 7 on the front and they have been added to the truck and some have been cut to fit they just made new clamps to hold them together and added longer U bolts and mine rides just fine can load a rick and 1/4 of green oak on it and the body drops maybe a inch good luck
Old Apr 17, 2007 | 07:05 AM
Pickupmanx2's Avatar
Pickupmanx2
I did the add-a-leaf on my 66 F-250, made a world of difference, I think it was under a hundred bucks, shipping and all, now she squats not near as much. Well worth it, I also added 1 1/2" - 2" leveling coils for a 94 F-150 4x4 in the front, had to use the plasma cutter of a friends a few times to get the ride where I wanted it, but that really helped the front-end stance and got rid of the sad sag look.
Old Apr 17, 2007 | 07:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
5 Leafs were standard (1250 load rate); 9 leafs were optional (1650 load rate)
There was a 6 leaf spring used in 1965, but it had the same load rating as the 5 leaf from 1966.
These were the only F100 rear springs offered 1964/72.
Old Apr 17, 2007 | 08:51 AM
snortf100's Avatar
snortf100
You can have the leafs rearched.
I decided to go with the original 5/1 leaf springs on my 1966 F100 4X4 and plan to add the Air Ride over the leafs for hauling. I have had add a leafs and extra leafs; they make the truck ride stiff. These trucks when Ford sold them in 1966 were a smooth riding truck that was the reason for the weak springs on the rear and up front. I sometimes wish I had that smooth ride again. That is not possible now for me as, I would need to remove the 4 inch lift kit and realign the front track arm to original specs.
Old Apr 17, 2007 | 11:40 AM
acheda's Avatar
acheda
Re-arching (or is it re-arcing?) the leaves is a good cure for sag to get back to a normal or slightly higher ride height, with a smooth ride.
Adding leaves will give higher ride height, greater load capacity, more stabile handling, AND a rougher ride. (You didn't expect that there would be no down-side, did you?)
If you can have the $$$, air bags or air shocks are the best way to have a good ride and be able to air up for more load capacity.
Old Apr 17, 2007 | 06:20 PM
carras's Avatar
carras
I just had a set made from new old stock on my 66. These leaves are 2-1/4" wide as opposed to 2-1/2" or 3" and were had to find. The spring shop made me a set from two new sets. He was glad to do it since he wasn't sure he'd be selling them anytime soon. Cost me 200 bucks. 7 leaves
Old Apr 17, 2007 | 08:49 PM
ras4434's Avatar
ras4434
When $ was tighter (tighter than now) I started cutting firewood for some extra bill paying power. A trip to the wrecking yard for a set of 3/4 ton springs and a couple of larger U bolts and she worked much better. So much better that she threw an axle because I put too much on once (gready). The moral of the story is dont get greedy but 3/4 ton springs will make a world of difference but as stated above she rides like a tank. I later went to a set of air shocks and that was better for just the "typical" truck stuff.
Old Apr 17, 2007 | 09:04 PM
onepeiceatatime
on the tank part with all the extra leafs my truck has in it it still rides moother than the 90 4x4 Trooper i have may also have something to do with the huge rear shocks it has on it or may be the way they did the leafs when they added then but it really isnt rough at all and alot smoother than the trooper
Old Apr 18, 2007 | 03:17 AM
NumberDummy
It also has to do with the fact that the Trooper has a much shorter wheelbase than the truck...the shorter the wheelbase, the bumpier the ride. For the ultimate in bumpiness, drive a Suzuki Samurai sometime...it's a teeter-totter on wheels.
Old Apr 18, 2007 | 06:20 AM
onepeiceatatime
no that is not it the trooper is a 4 door and is longer than the 62 was talking to my dad about the truck last night and even he thought it has a fairly smooth ride and yes he has drove it down a rough dirt road all i9n the way they did the modification i guess but it does ride smooth i can set a can of pop behind the shifter and run 20 down a dirt road and it stays right put if that gives you a idea
Old Jan 16, 2008 | 01:01 PM
Payner44's Avatar
Payner44
1966
Bill, just curious, what is the standard factory leaf count front and back for a '64 2WD?
rockcrawler_101
May 27, 2011 12:08 AM
Bigblack Ford
Jul 26, 2009 01:16 PM
1998 Explorer Sport
Sep 11, 2006 03:53 PM
my64ford
Jan 29, 2003 09:49 PM
