Check Engine Codes....GGGGRRRRRR
Old Apr 16, 2007 | 05:22 PM
roperjoe's Avatar
roperjoe
So, here it is: 1996 F-150 4.2L V6, 160K Miles
Going back a couple months....
CE light comes on, registering #3 and #6 misfires. I pull the plugs, check the gaps. Check wires. Light remains on. So, I replace plugs and wires...message displays again. I replace the Coil Pack.....light comes back on. This time, I am also getting EGR valve Insufficient Flow. So, I pull the EGR and clean it out. Light comes back on...now I have the #3 and #6 valve misifiring, EGR valve, and the new one...a P1506 Idle Code. Does anyone have any ideas? Could it be the computer is crapping out on me? I am at my witts end here. Thanks guys.
Old Apr 19, 2007 | 07:30 AM
projectSHO89's Avatar
projectSHO89
Nothing wrong with your computer, it's just identifying all the other stuff that's crapping out.
EGR codes are ususally due to a faulty DPFE sensor, however, there are other possibilities. EGR valves are usually NOT the problem.
The idle-related code is likely due to a gummed-up IAC valve, very common.
The misfires may be due to plugs, wires, coils, injectors, intake gasket leaks, or other base engine mechanical faults.
Steve
Old Dec 26, 2009 | 11:55 AM
ruralheating's Avatar
ruralheating
could a dirty or bad IAC cause oxy sensor codes as well?
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
techsuphunt
Escape & Escape Hybrid
May 1, 2008 10:28 PM
Eric1997f150
1997 - 2003 F150
Oct 10, 2006 08:03 PM
mcgeenl
Jul 30, 2006 10:03 AM
dcale101
1983 - 2012 Ranger & B-Series
30
Nov 19, 2004 06:05 PM
