1978 - 1996 Big Bronco
Water ON the engine!
Old Dec 3, 2001 | 01:36 PM
tombob's Avatar
tombob
Following a rain--my poor old Bronco (351W 1980) sits outside--water pours into the engine compartment and pools on top of hte air cleaner.I think the reason is that a gutter-like attachment on the firewall (inside engine compartment) that was designed to channel water coming through the hood junction at the firewall has deteriorated.
Can I get a replacement? I assume I can go to a junk yard and see, but what is the name of this piece? Would any paarts off a F-100 or 150 fit this?
Old Dec 3, 2001 | 03:51 PM
broncoman's Avatar
broncoman
Old Dec 3, 2001 | 06:56 PM
restorit's Avatar
restorit
You're right.... there is a black piece that's supposed to fit in to work as a gutter / seal. It is attached using the same screws that fit through the cowl panel from the engine compartment side. One from an F150 will work. LMC Truck sells the piece for around $40.00 or so. (I believe it's called a "Hood to Cowl Seal".
Baumbach
38
Jul 20, 2024 06:40 AM
gbakman
24
Oct 17, 2016 06:17 PM
whalerron
Jul 3, 2016 09:36 PM
waumpuscat
Jun 18, 2014 12:23 PM
SLUF681
Jan 10, 2011 07:54 AM
