1978 - 1996 Big Bronco
Tailgate glass replacement??
Old Nov 30, 2001 | 06:35 AM
Big_Ben's Avatar
Big_Ben
Old Dec 2, 2001 | 09:25 AM
Bronco95's Avatar
Bronco95
I just picked up a used 95 Bronco yesterday and decided to take it to the manual car wash for a scrub. Upon leaving, it's my guess that I didn't fully latch the spare tire carrier and it whacked the tailgate, thus shattering my rear glass!!! So, I'm a bit pissed!! I can't imagine how else it would have happened?? But anyway, is the glass replacement easy?? Is junkyard glass cheap and easy to find or should I take it to a glass place to have it done?? Thanks in adavance for the help..........Joe
Old Dec 2, 2001 | 02:00 PM
AlM's Avatar
AlM
Here you go,
http://users.superford.org/ylobronc/tailgate/tailgate.html
thanks to Dustin!
also,
http://www.off-road.com/ford/bigbroncos/tech/window-fix.html
Old Dec 3, 2001 | 01:17 PM
honney's Avatar
honney
It's entirely possible the torsion bar broke free w/in the tailgate and shattered the window. Anyway, pull the access panel and take a closer look.
Old Dec 3, 2001 | 04:12 PM
Bronco95's Avatar
Bronco95
If the torsion bar let go, would it shatter the window even if it was in the up position??
Old Dec 3, 2001 | 10:40 PM
mrlaserboy's Avatar
mrlaserboy
There is no tension on the torsion bar when the tailgate is in the full upright position, so to answer your question- no. Check around with your local glass companies, you may be surprised at the cost of the rear glass, probably not as much as you expected.
Old Dec 4, 2001 | 06:03 AM
Bronco95's Avatar
Bronco95
Laserboy,
Thanks for the advice. I suppose it was the loose tire carrier after all. I called a local glass place and got a quote of 230 dollars installed. I went with it. They came while I was at work and did the job. Perfect. I figured it saved me the trouble of finding the glass at the boneyard and taking the time to install it myself.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
