Battery Light
Old Jun 13, 2007 | 04:28 PM
cangim's Avatar
cangim
It seems a tha a lot of the rebuilt alternators are actually for gas engines that have a higher idle RPM. Our diesels idle much lower which is more than likely the cause of the headlight dimming affect some have experienced. If the batt light is flickering or on and the truck starts fine, I would definately start at the alternator. I ordered one of ebay as a preventative maintenance thing. Once I pulled the original off, I could definately tell the bearings were starting to wear. So now I have the original as a backup if I ever need it.
Old Jun 13, 2007 | 04:39 PM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by crosbo
......20 miles down the road the flickering starts again...10 more miles and it goes constant......it almost seems "bump related"........
If it is bump related you have a loose wire or connector some where. I think your alt. is failing and will drain your batteries and leave you stranded soon. Save your batteries and replace with a good quality, high amp alternator that is made for our trucks. Although not a popular choice here, I got mine from AutoZone. I got the lifetime warranty one and that was 2yrs ago and still doing fine.
techno101
Jan 17, 2015 09:48 PM
VikingBabe
General Automotive Discussion
Nov 13, 2013 11:59 PM
yerblor
Oct 7, 2010 07:57 PM
mattpowerstroker
18
May 1, 2009 02:25 AM
kochy54
15
Apr 21, 2002 05:31 PM
