Sponsored by: Auxito
'97 Ford F150
Old Oct 15, 2002 | 05:32 PM
gmbpilot757's Avatar
gmbpilot757
'97 Ford F150
Hey all-
I'm looking at a '97 F150...Triton 4.6L. It has a 4" suspension lift on it, 35's, and 80K mi. The only thing I'm concerned about is the fact that it has the 4.6L in it. So I'm thinking about slappin' on a Kenne Supercharger. Does this sound worth it or should I look for the 5.4L? Any advice would be appriciated! Thanks-
Old Oct 15, 2002 | 09:24 PM
z 97ford1's Avatar
z 97ford1
'97 Ford F150
I bought the same truck 4x4 new in 97. Take it from me. It is not enough power. It's barely on the edge. You think your going to save money on gas saved...not worth it.
Get a more powerful truck!!!!!!
Old Oct 16, 2002 | 10:40 PM
jbrou27's Avatar
jbrou27
'97 Ford F150
Honestly I have almost the same truck. 6" inch lift, 35in tires and the 4.6. It really all determined how you have the differentials geared. 3.55 you'll want a bigger engine. 3.73 you're on the edge. 4.10 and you be happy with it. I have enough power to pull my boat in OD on flat roads and running empty on the highway i can make 16 to 17 mpg.
jerome
Old Oct 20, 2002 | 07:28 PM
Doorgunner808's Avatar
Doorgunner808
'97 Ford F150
Jbro is right the truck will do fine as long as you have the right gears in the diff's. If you have the factory gears in with 35 in tires you will have the feeling that the truck is way underpowered. 4.11's will be ok but with 35's i would suggest 4.55's or 4.88's. If you are getting a good deal on the truck and have some money to spare, most shops charege about 500 to 700 dollars to buy and install gears per differential. Putting the lower gears (higher numerically) will also put the driveline RPM's back to factory specs as if to have the oem size tires on it as well. I hope this helps you out.
DG808
Old Oct 26, 2002 | 06:13 PM
BLU98's Avatar
BLU98
'97 Ford F150
Do you guys have any pics of you lifted 97's-98 F-150's? I'm in the middle of deciding on if I should get mine lifted or not? Also, what size tires and gears did you use? Please E-mail me at jessesmustang(No Email Addresses In Posts!)
Old Oct 30, 2002 | 08:30 PM
geoaigel's Avatar
geoaigel
'97 Ford F150
Old Oct 31, 2002 | 08:09 PM
geoaigel's Avatar
geoaigel
'97 Ford F150
The 4.6 is a good engnine with tons of potential. All the mustang performance parts practically work on it. If you rev it a bit more than most people are used to on truck V8s it performs quite well! A supercharger would be a great idea!
Mine is getting a tad bit high in the mileage (155k), if it ever goes and I put a new (4.6l!), I'll go with a mild supercharger...
George
riverbottom
1997 - 2003 F150
Oct 15, 2009 01:55 PM
stiffnecked
Modular V8 (4.6L, 5.4L)
Mar 1, 2009 02:53 PM
bigj-dog
Feb 14, 2007 09:36 PM
z 97ford1
1997 - 2003 F150
Jul 6, 2006 08:42 AM
CMOS
2004 - 2008 F150
Nov 23, 2005 04:07 PM
