1978 - 1996 Big Bronco
Clunk CLunk
Old Nov 28, 2001 | 11:59 AM
albertaguy's Avatar
albertaguy
Clunk CLunk
Hello:
I am driving a stock 1986 Ford Brono with a 5.0 Liter engine.
Everyone once and a while when i put it into gear and drive away i hear terrible clunking coming from underneath. In the cab it feels like the whole bottom is going to fall from the truck.
Any ideas on what it could be ??
Ward
Old Nov 28, 2001 | 02:35 PM
Mil1ion's Avatar
Mil1ion
Clunk CLunk
Ford trucks have a problem with driveshafts clunking.
They just do it.
I stopped mine by putting a moderate amount of high temp wheel bearing grease on the driveshaft spline and shoving it back on.
It works.
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Nov 28, 2001 | 07:45 PM
JBronco's Avatar
JBronco
Clunk CLunk
Mine was clunking and vibrating. One of the cv joints (they are cv joints, not u-joints. It's a constant velocity shaft) was sticking, and you can't tell without taking the shaft off and rotating the joints around. You will feel a spot where it is sticking if it is bad. I had the shaft rebuilt and balanced, cost $350 but the truck drives 1,000 percent better. If you are sure your cv joints are good then greasing that center spline seems to be working for most folks. I'm not sure what the consensus was about how to remove the boot and put it back on, the the best idea I saw was to simply slide it up with the factory clamp on, and then slide it back down after you grease it. Apparently the clamp is not so tight that you can't move it. Someone said this worked for them.
Old Nov 29, 2001 | 10:44 AM
adelyser's Avatar
adelyser
Clunk CLunk
Here is the easiest way to lube the drive axle slip-joint:
I had a similar problem on my '94 EB, and the problem was occuring in the slip-joints on the driveshafts. The joints would stick, and under enough force, would compress and make the clunk noise, which was quite loud. I went to the local feed store and bought a large syringe and a big needle. I then jacked up the back by the frame, filled the syringe with grease from my grease gun, and inserted the needle into the rubber boot around the slip-joint. After applying the grease, I did the same for the front drive shaft, and the problem went away after a couple of miles. I think the total cost was about $5.
Aaron D.
Old Nov 29, 2001 | 11:12 AM
honney's Avatar
honney
Clunk CLunk
Your '94 still has a slip-shaft in the d/s itself and not at the t-case? Also, it's recommended to use a high-pressure grease on the slip shafts (most moly lubes say they're rated for high pressure).
Old Nov 29, 2001 | 11:41 AM
adelyser's Avatar
adelyser
Clunk CLunk
Yeah, I have a slip-shaft in both the front and rear driveshafts. The rear driveshaft bolts to the flange on the transfer case, and there is a CV joint on the driveshaft side of the assembly.
Old Dec 13, 2001 | 07:18 PM
chaser's Avatar
chaser
Clunk CLunk
Old Dec 16, 2001 | 10:50 PM
burglar's Avatar
burglar
Clunk CLunk
i would just like to say thank you to all the guys who knew how to fix this problem. i've been to 7 different mechanics over the last 3 years trying to get it fixed and no one knew what it was. i was about to sell it because one of them told me it was the transmission and it would have to be rebuilt. and a 3 dollar tube of grease fixed it. thanks guys i really didn't want to get rid of my Bronco. beers on me tonight.
Burglar
