So, whats the chances?
Old Apr 14, 2007 | 10:22 AM
Talyn's Avatar
Talyn
Alright, my 302 is letting me down, and I'm getting bored with the lack of simple gas engine modifications.
I've never ridden in an earlier 7.3 power stroke, so I don't know a whole lot about them but general power stroke info.
I've ridden in the newer 2000+ models, and decided I wanted a 6 speed, boy that low gear is fine. =)
The 2 speed rear differential is nice also!!!
However, I dont think those are available for these years (stock) correct me if i'm wrong.
Alright, here's what I'm looking for, please tell me if I'm dreaming about obtaining.
The only thing that dosn't matter is if its a regular, cab 1/2 or quad.
4wd is given.
I need a 3/4 ton, or 1 ton diesel Truck, with a 5 or 6 speed manual transmission, 8 foot bed, and cablights. (Cablights are so important)
I know i can't have my wonderfull independant front susspension i so enjoy on my 1/2 ton, or can I? I'm not going to be plowing with this truck, I just want to upgrade to diesel. And a desil swap is out of the question, I dont want that much work, and my truck is ready to be traded out to somebody who needs a nice, well, i guess the best way to put it, a good introduction truck.
Old Apr 14, 2007 | 10:37 AM
tjbeggs's Avatar
tjbeggs
your not dreaming at all. f-250 had the TTB front suspension but be warned it doesn't ride well and doesn't like the weight of the diesel on it. I would go a F-350 but thats up to you. there are many body styles 250 and 250 both come in regular cab long box, 250 also comes in extended cab long box or crew cab short box. the 350 also offers a crew cab long box but no short bed or extended cab version.
cab lights are easy to install if you find just the right truck without cab lights. the superduty cab light look excellent of one our trucks.
Old Apr 14, 2007 | 10:55 AM
Talyn's Avatar
Talyn
I dont want to do any installing of anything like cablights.
The most i'll put on is a visor.
Seems if i get the TTB susspension, it can be beefed up for the desil a bit better with some stiffer springs and better shocks.
Tim, go over to our michigan chapter forum and join up too. =)
Link is in my signature.
Old Apr 14, 2007 | 01:38 PM
tjbeggs's Avatar
tjbeggs
the 250 springs are actually thicker and stiffer than the one ton because of the twist that is put on the springs by the TTB. its up to you though. the TTB dana 50 can be a good axle but it takes an expert alignment tech and some time. also requires religious tire rotations every 5k miles.
Also I tried to join the MI chapter once and haven't heard anything. maybe I did something wrong. I will try again.
where you at in michigan?
Old Apr 14, 2007 | 01:40 PM
tjbeggs's Avatar
tjbeggs
well just tries to join and it said I am already a member! who knew!!??
Old Apr 14, 2007 | 02:32 PM
Talyn's Avatar
Talyn
Yea, i have some issues with my TTB due to the previous owner thinking he was a mechanic.
I know those radius arms ahve to be up to snuff, and all your ball joints need to be atleast 90% to get a good alignment. =)
However, i've never had to rotate that often, but it dosn't hurt.
I understand more and moer about the axle the more i use it.
The only thing i think i'm goign to be bumming on is looseing my rims that i got, the nice 5 bolt aluminum ones from my 91 nite. =*(
Old Apr 14, 2007 | 03:10 PM
glasseater's Avatar
glasseater
i like solid axles lol
Old Apr 14, 2007 | 03:28 PM
tjbeggs's Avatar
tjbeggs
the 250 don't have radius arms but the leaf springs locate the axle but the leaf spring bushings do wear out. and the ball joints need to 100% on these heavier trucks.
Old Apr 14, 2007 | 05:49 PM
Talyn's Avatar
Talyn
oh the TTB's on the 250's are leaf springs? not coils? No wonder they sag. If i'm going to have leaf springs on my truck, it better be solid front axle.
i like the performance i get from my TTB, (whatever that stands for i duno still)
Takes a bit more work though.
I can see why they have problems aligning them if they are setup like that. Radius arms make that setup possible.
They runnign floating rear ends in most of them, or can i expect a 9"?
What they putting in for the fronts? those are 40's or 60's?
Old Apr 14, 2007 | 07:17 PM
tjbeggs's Avatar
tjbeggs
250 and 350 rears are sterling full lfoating 10.25 ring gears. very good axles. the front of the 250's are dana 50 TTB(twin traction beam) and the front of the 350's are dana 60's both fronts are leaf sprung
Old Apr 14, 2007 | 07:47 PM
Talyn's Avatar
Talyn
I thought the rear was only semi floating?
Sounds like it would be a fun project to take the 150 body of your choice and put a diesel in it frame up.
unforuantly, i dont have that kind of time or money. =*(
Old Apr 14, 2007 | 09:08 PM
glasseater's Avatar
glasseater
do the 250's and 350's have 60's for the rears? sorry if this is a lil off-topic but i'm just wondering
Old Apr 14, 2007 | 09:14 PM
tjbeggs's Avatar
tjbeggs
nope they have the sterling 10.25 axle. no dana's outback till you get the f-superduty (OBS F-450)
Old Apr 15, 2007 | 12:31 AM
skittlejr's Avatar
skittlejr
would that twist cause one of the front shackles to hang at an angle instead of straight down? maybe the springs are worn out?
Old Apr 15, 2007 | 12:51 AM
kellens's Avatar
kellens
2 speed rear end???
I have never seen a 250/350 with a 2 speed rear end. That would be totally awesome though!
