No power to trailer while in reverse?
I temporarily worked around this by splicing into the backup lights, and jamming the other end of the wire into the trailer end of the connector (flat 5). Obviously I'm not happy with this as a permanent solution.
Where should the voltage come from to power this solenoid?
2001 F150 SuperCrew w/ factory towing package
You can confirm it by jacking one side up and pulling the brake drum.
If there is no magnetic brake assembly in there, you have a surge brake.
If a solenoid is disconnecting the brake on backup, and you have to jumper it - YOU HAVE A BAD CONNECTOR....
Look at your plugs, use a meter, and find the bad connection.
If the factory plug on that 150 is a flat 4-pin you need to replace it with a flat 5-pin, wired so the extra pin powers the lock-out solenoid when in reverse. If the factory plug is a round 7-pin, you can buy a 7-into-5 adapter for around $12.
Steve
If I have a bad connector, it is in the round, six connector, socket. I have an adapter that goes from there to a flat five. The truck came stock with both flat four and round six prong connectors.
Really, I'm just looking to where the power should come from. If it is the backup lights, I'll wire it in from there. If it is from somewhere else, I'd like to know.
Chet
Here's your wiring diagram: http://www.accessconnect.com/trailer_wiring_diagram.htm
If I'm reading it right, the 12v pin is hot with ignition key on; you don't have a breakaway battery to charge, so you could rewire this pin for back-up light power to activate the lock-out solenoid. Just make sure your 6-into-5 adapter works for this set-up. If not, you may have to rewire the electric brake pin for back-up power, but one of these ways should get you juice to the trailer plug's pin for the solenoid.
I doubt that round 6-pin connector is from the factory, especially on an '01, but I could be wrong.
Steve
